Solve Velocity Problem: Dropped from 3m, .5m Radius, .2kg Mass
  • Thread starter titusdna
  • Tags
    Velocity
In summary, the conversation discusses the calculation of the speed of a hoop with a radius of .5m and mass of .2kg released from rest and rolling down an inclined plane. The formula v=Iw/md was initially used, but since there was no information about angular velocity, the formula v=sq root 2xgxh was used instead. However, the online test is indicating this answer is incorrect and the possibility of using the wrong formula is raised. The concept of energy conservation and the relationship between linear and angular velocities is also mentioned.
titusdna
A hoop with a radius of .5m and mass of .2kg is released from rest and rolls down inclined plane. How fast is it moving after dropping from vertical distance of 3m? First I tried v=Iw/md but I had no info for angular velocity so I tried calculating using v=sq root 2xgxh and get 7.7m/s but my online test is saying it is wrong. Am I using the wrong formula?
Thanks
Thanks
Energy will be conserved. You seem to have some idea what moment of inertia and angular velocity are, so you are not far away from the result. Kinetic energy can be broken into the kinetic energy of transaltion and the kinetic energy of rotation. The first depends on linear velocity of the center of mass. The second depends on angular velocity about the center of mass. Firgue out the connection between those velocities assuming the hoop is NOT SLIPPING.
for your question. It looks like you may be using the wrong formula for this problem. The formula you are using, v = √(2gh), is used to calculate the final velocity of an object that has been dropped from a certain height (h) and is falling straight down due to gravity. However, in this problem, the hoop is not falling straight down, it is rolling down an inclined plane. This means that it has both translational and rotational motion, and therefore, the formula for its final velocity will be different.
To solve this problem, we can use the conservation of energy principle. The initial potential energy (mgh) of the hoop at the top of the inclined plane is converted into both translational and rotational kinetic energy as it rolls down. The equation for this is:
mgh = (1/2)mv^2 + (1/2)Iω^2
Where m is the mass of the hoop, h is the vertical distance it is dropped, v is the final velocity, I is the moment of inertia (for a hoop, it is equal to mR^2 where R is the radius), and ω is the angular velocity.
Since the hoop is released from rest, its initial velocity (v0) and initial angular velocity (ω0) are both zero. Therefore, the equation becomes:
mgh = (1/2)mv^2 + (1/2)mR^2ω^2
Rearranging for v, we get:
v = √(2gh - R^2ω^2)
To find the final angular velocity, we can use the formula ω = v/R, since the hoop is rolling without slipping. Substituting this into the equation above, we get:
v = √(2gh - v^2)
Solving for v, we get v = √(4gh/3) = 7.7m/s. This is the correct answer.
I hope this helps clarify the problem and the correct formula to use. Good luck with your online test!
What is the formula for velocity?
The formula for velocity is v = d/t, where v is velocity, d is distance, and t is time.
How do I solve for velocity?
To solve for velocity, you need to know the distance and time. Plug those values into the formula v = d/t and solve for v.
What are the units for velocity?
The units for velocity are meters per second (m/s) or kilometers per hour (km/h).
How does mass affect velocity?
Mass does not directly affect velocity. However, a heavier mass may require more force to accelerate to a certain velocity.
What is the acceleration due to gravity?
The acceleration due to gravity is 9.8 m/s^2. This is a constant value for objects in free fall near the Earth's surface.
