Velocity time graph
  1. Feb 3, 2013 #1
    http://imageshack.us/photo/my-images/96/caracarbgraph2.png/[PLAIN]
    [b]2. Relevant equations[/b]
    This image is 2 cars, and Car 1 is starting at a higher velocity rate than Car 2, which is constant @ t = 0. Now then, the car is ahead and then decreases speed over time, I am trying to figure out when car 2 well eventually catch up to car 1.
    [b]3. The attempt at a solution[/b]
    I am not sure if there is any equation to this, but it looks like they go the same speed at 5 seconds, the slope of car 1 is 6 m/s^2 (70 m/s - 10 m/s = 60 m/s/10s = 6m/s^2) However I'm not even sure if that actually helps.. since car 2 has a slope of 0.
  3. Feb 3, 2013 #2
    rollingstein
    http://img96.imageshack.us/img96/7369/caracarbgraph2.png [Broken]
  4. Feb 3, 2013 #3
    ehild
    You need to know what was the initial distance between the cars.
    ehild
  5. Feb 3, 2013 #4
    rollingstein
    [STRIKE]40 t = 70 t + 1/2 * (-14) t^2[/STRIKE]
    My bad.
    40 t = 70 t + 1/2 * (-6) t^2
  6. Feb 3, 2013 #5
    ehild
    That would be true when they start from the same place (if you used the correct acceleration).
    ehild
  7. Feb 3, 2013 #6
    rollingstein
    In the absence of other info. I assumed that, yes.
  8. Feb 3, 2013 #7
    Why -14?
  9. Feb 3, 2013 #8
    rollingstein
    What's acceleration?
  10. Feb 3, 2013 #9
    ehild
    That is not -14. Check.
    ehild
  11. Feb 3, 2013 #10
    rollingstein
    Right. My blunder. -6.
  12. Feb 3, 2013 #11
    rollingstein
  13. Feb 3, 2013 #12
    It's a quadratic right? How did you know to use that formula?
    so A = -3, B = 30, and C= 0
    = -5 (+/-) SQRT(1) = 0, and 10
    So 10 seconds is the answer.
  14. Feb 3, 2013 #13
    rollingstein
    Which?
  15. Feb 3, 2013 #14
    ehild
    What kind of motions are involved?
    ehild
  16. Feb 3, 2013 #15
    Displacement, acceleration, initial velocity, and time?
  17. Feb 3, 2013 #16
    ehild
    Car A moves with constant acceleration. You should know the formula for displacement in terms of time.
    ehild
  18. Feb 3, 2013 #17
    x =v0t + ½*at2
    But it was setup that x was 40t because the distance was needed between the 2 cars correct?
  19. Feb 4, 2013 #18
    ehild
    If the set-up was that both cars started from the same position x=0, then the position of car A is xA=70t-3t2 as function of the time t and the position of car B is xB=40t. Car A leaves car B at the start, but slows down and car B catches it at the end. At that instant, both cars are at the same place again, xA=XB. 40t=70t-3 t2
    ehild
Similar Discussions: Velocity time graph
  1. Velocity-time graph (Replies: 6)
Loading...
