• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Venturi meter help
  • Thread starter ahello888a
Venturi meter help!!!
1. Homework Statement
A venturi meter is measuring the flow of water; it has a main diameter of 3.0 cm tapering down to a throat diameter of 1.0 cm. If the pressure difference is measured to be 16 mmHg, what is the speed of the water entering the venturi throat?
2. Homework Equations
-+P_2+%7D+%5Cright%29%7D%7D%7B%7B%5Crho+%5Cleft%28+%7BA_1%5E2+-+A_2%5E2+%7D+%5Cright%29%7D%7D%7D.gif
Got that equation from a previous part of the problem where it asked me to "Show that the flow speed measured by a venturi meter (see Figure 13–32 in the textbook) is given by the relation"
3. The Attempt at a Solution
I used [tex]\rho[/tex] to be density of water. I converted the diameters to radius in meters. I converted the pressure to "m-Hg". I get 1.77*10^-5. The homework program keeps telling me I'm wrong. I can't see what I'm doing wrong. Thank You for the help!
tiny-tim
25,790
247
Hi ahello888a! :smile:
(you said mmHg as the top, and m Hg at the bottom … is that a typo?)
erm … we need to see your full calculation if we're going to find out where it's wrong! :wink:
stewartcs
Re: Venturi meter help!!!
Start by writing out the energy balance using the Bernoulli equation.
Hints:
Assume the elevation change is zero.
Neglect the small friction.
Use the continuity equation.
Hope this helps.
CS
Related Threads for: Venturi meter help
  • Posted
  • Posted
  • Posted
  • Posted
15K
  • Posted
15K
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
