Verify that it's a vector
  1. Jan 5, 2017 #1
    Show that (ap1,bp2) is not a vector unless a = b.(The 1 and 2 are superscripts)
    In Einstien's Gravity in a Nutshell, p 43, Zee states the above is not a vector because it doesn't transform like a vector under rotation. When I use the usual rotation matrix for rotation about the z axis (R11 = cosQ, R12 = sinQ, R21= -sinQ, R22 = cosQ), then check that length is preserved under this transformation, I get that this is in fact a vector.
    Zee gives another example: (x2y, x3+y3). This, too seems to preserve length after being multiplied by the rotation matrix. What am I missing?
    I would be happy to have an explanation for either example, of course.
    2. Relevant equations
    3. The attempt at a solution
    I will use the first example, but make the notation easier by starting with the "vector" (non-vector?) (ax, by) = r.
    r' = Rr = (axcosQ+bysinQ, -axsinQ + bycosQ)
    squaring r' gets (axcosQ)2 + (bysinQ)2 +axbysinQcosQ + (-axsinQ)2 + (bycosQ)2 -axbysinQcosQ = (ax)2 + (by)2, which is r2, so length is preserved.
    Seems pretty straightforward, so: say what?
  3. Jan 6, 2017 #2
    TSny
    2017 Award
    Welcome to PF!
    When you write r' = Rr you are assuming that r is a vector. But you actually want to show that it is not a vector (if a ≠ b).
    You are given that ##(x, y)## is a vector. So, ##(x', y')## is equal to the rotation matrix applied to ##(x, y)##. That is, you know how ##x## and ##y## transform when going to the primed frame.
    When you write ##(ax, by)##, then ##x## and ##y## are still the components of the vector ##(x, y)##. ##a## and ##b## are assumed to be scalars; so, they don't change when going to the primed frame. Therefore, the quantity ##ax## transforms as ##ax## → ##ax'##. Similarly for ##by##. So, you can see how ##(ax, by)## transforms. Then you can check whether or not ##(ax, by)## transforms as a vector.
  4. Jan 13, 2017 #3
    Thank you so much! (:doh: Of course!)
Have something to add?
Draft saved Draft deleted
Similar Discussions: Verify that it's a vector
  1. Someone verify? (Replies: 8)
  2. Verify this concept? (Replies: 8)
Loading...
