I Vertical line debunking
  1. Mar 15, 2019 at 9:22 PM #1
    Recently, after work beers with a colleague went down a bit of rabbit hole as he attempted to "red pill" me on a couple of topics. One of those happen to relate to the below self-published paper, which was written by someone he went to college with:
    https://www.slideshare.net/MrIndererminate/indeterminate-is-not-synonymous-with-undefined
    It seems rather compelling on first read, but acknowledging that it is above my paygrade, I decided to search the internet to see if counter arguments had been made, which led me to a thread on this forum, where the paper had been mentioned:
    https://www.physicsforums.com/threads/graphing-a-strange-equation.912296/
    To ensure I can convey the pro-hole argument effectively, I'm just going to lay out my simple version of it below:
    Equality A [ y = (x^2-1)/(x-1) ] cannot be rearranged into Equality B [ y (x-1)=(x^2-1) ] ,as this would involve division by zero.
    It is true that graphing B on a cartesian plane will result in a vertical line. However, this does not mean that a vertical line should be depicted when graphing A, as it cannot be rearranged into B without fundamentally changing the equality.
    For A, when x=1 y=0/0. Thus hole at co-ordinate (1,2) is the appropriate depiction for A, as all division by zero is undefined.
    Is this correct? Are there any other points I should add?
  3. Mar 15, 2019 at 10:53 PM #2
    fresh_42
    2018 Award
    Staff: Mentor
    It can, if the range of allowed values for ##x## is considered. In detail we have:
    A \Longrightarrow B \stackrel{x\neq 1}{\Longrightarrow} A
    ##A## has implicitly given that ##x\neq 1## (otherwise the quotient makes no sense), whereas ##B## has not. So in order to get back from ##B## to ##A##, ##x\neq 1## has to be added.
    No.
    The only difference is, that ##A## has a gap at ##x=1## where it is not defined.
    Yes, this is correct, only that the line isn't vertical, more diagonal.
  4. Mar 16, 2019 at 4:59 PM #3
    Equality B absolutely has a vertical line!!!
    It can be graphed on a cartesian plane, by inserting values in for y and then solving for x:
    For instance, if y=3 then:
    3(x-1)=x2-1
    3x-3=x2-1
    3x=x2-1+3
    3x=x2+2
    0=x2-3x+2
    0=(x-1)(x-2)
    Thus x = 1 or 2 and so the co-ordinates (1,3) and (2,3) are plotted
    Repeat this with different values for y and a vertical line in the graph where x=1 will be apparent.
  5. Mar 16, 2019 at 5:36 PM #4
    fresh_42
    2018 Award
    Staff: Mentor
    This is completely wrong.
    ##B## reads ##0=0## for ##x=1##, which doesn't give us anything. For ##x\neq 1## equation ##B## is equivalent to ##y=x+1##. So unless you do not introduce another coordinate system, the usual graph is ##\{\,(x,y)\,|\,y=x+1\,\}## which is the line in the image above. It is diagonal and shifted by one up. This is not vertical.
  6. Mar 16, 2019 at 6:00 PM #5
    Is the method of inserting values for y to determine x not a valid method of graphing equations?
    I would read https://www.physicsforums.com/threads/graphing-a-strange-equation.912296/ before you answer that. Numerous senior forum members have agreed in the past that B does indeed have a vertical line (It has never been said that the graph is solely composed of vertical line).
  7. Mar 16, 2019 at 6:12 PM #6
    fresh_42
    2018 Award
    Staff: Mentor
    O.k., the solution ##x=1## is valid, too, as ##B## is a tautology in this case. So you are right, the graph of solutions is
    Sorry.
  8. Mar 16, 2019 at 9:28 PM #7
    Alright now that we are on the same page on that one. I'm going to come out and say that I don't agree with NATE MATE's argument.
    For equation B, if x=1 then y= 1 or 2 or 3 or -4 or 0.34928 or -200 ....... basically its any number. Merriam-Webster defines indeterminate as "Having an infinite number of solutions". Thus, I'm inclined to conclude that for equation B if x=1 then y=Indeterminate.
  9. Mar 16, 2019 at 10:35 PM #8
    fresh_42
    2018 Award
    Staff: Mentor
    If ##x=1## then ##\forall\, y\, : \,y(x-1)=x^2-1##. I don't think we can call ##y## indeterminate. ##y## cannot be determined, yes, but the reason is, that ##y## is simply not part of the statement anymore, since ##y\cdot (1-1) =0## and ##B## is reduced to ##x=1\,\wedge \,0=0## as part of the assumption to ##B## in this special case. It's somehow as if we said, that ##z## is indeterminate. So without an occurrence, can you attribute an adjective? The statement ##B## is probably better called a tautology and ##y## cannot be referenced anymore.
    If ##x\neq 1## then ##y=x+1## and ##y## is determined.
    So ##B## determines ##y## in some cases, and does not determine ##y## in another case. But that doesn't make ##y## indeterminant, since it vanished!
  10. Mar 17, 2019 at 2:48 PM #9
    Ray Vickson
    The formula ##f(x) = (x^2-1)/(x-1)## defines a valid mathematical object only if ##x \neq 1##. It describes a perfectly well-defined mathematical function on the open domain ##(-\infty, 1) \cup (1, \infty),## which is the real line with the value ##x=1## missing. Of course, on that domain we have the simpler version ##f(x) = x+1##, and that form can be extended to the whole line, including the point ##x=1##.
    If you want to plot a graph of ##y = f(x)## by choosing ##y## and then solving for ##x## you will find that the value ##y=2## is missing: there is no solution of the equation ##2 = (x^2-1)/(x-1)##. Of course, there is a solution of ##2 = x+1##, but that is a different problem for a different function.
    I think one needs to be careful to distinguish between "no solution" and "non-unique solution = vertical line". To a certain extent, we can argue that it is a matter of taste: I prefer to go along with standard mathematics that regards---for excellent reasons--- division by zero to be always disallowed. Others, who may have a more informal and flexible set of mathematical rules, will regard something like 0/0 to be whatever they want.
  11. Mar 19, 2019 at 3:59 AM #10
    So with equation A ##y=(x^2-1)/(x-1)## you say a hole is the appropriate depiction.
    Do you agree that equation B ##y(x-1)=(x^2-1)## has a vertical line?
  12. Mar 19, 2019 at 2:47 PM #11
    Ray Vickson
    That does not really matter, since that is for a different problem. When trying to go from A to B you are essentially saying that when you write
    $$(x-1)y = \frac{x^2-1}{x-1} (x-1) \hspace{4ex}(1)$$
    you want to cancel the ##(x-1)##s in the numerator and denominator on the right and so be left with just ##x^2-1##. That cancellation is valid for all ##x \neq 1##, but when ##x=1## it is pulling the old ##0/0 = 1## trick, which is invalid for main-stream mathematics.
  13. Mar 20, 2019 at 12:14 AM #12
    Ok, so what your saying is that equation A cannot be rearranged into equation B.
    However, if you were just to start with equation B, would it be depicted with a vertical line?
Have something to add?
