bob012345
- 890
Is it possible to make very low frequency EM waves, say 10 KHz, without an antenna the size of Texas? Something more human sized? Thanks.
Say 1 KW. How does it scale?berkeman said:
To transmit any substantive power, you will need an efficient antenna, which means on the order of λ/4 to λ/2.bob012345 said:Say 1 KW. How does it scale?
I'm guessing signals would follow the water around the surface and interfere with Naval communications. Is that close? I'm interested in knowing or finding a mechanism to transmit a strong Lorentz force between objects at a significant distance. I think low frequency interactions would be easier to deal with. One application could be manipulating objects in low Earth orbit.berkeman said:To transmit any substantive power, you will need an efficient antenna, which means on the order of λ/4 to λ/2.
What application do you have in mind? If you try transmitting that kind of VLF power and you live anywhere near the ocean, you will probably get a visit from a blue van pretty quickly. Quiz Question -- Why?
Mostly that VLF is used for some submarine communications, so I don't even know if you could get a license to transmit in the VLF band.bob012345 said:I'm guessing signals would follow the water around the surface and interfere with Naval communications. Is that close?
berkeman said:Mostly that VLF is used for some submarine communications, so I don't even know if you could get a license to transmit in the VLF band.
As an illustration, the 16 kHz transmitter (callsign GBR) at Rugby, UK, now defunct, used a 1MW transmitter and achieved a radiated power of about 20kW. The antenna masts were 820 feet high and the area of the transmitting antenna was about a square mile.bob012345 said:Is it possible to make very low frequency EM waves, say 10 KHz, without an antenna the size of Texas? Something more human sized? Thanks.
tech99 said:As an illustration, the 16 kHz transmitter (callsign GBR) at Rugby, UK, now defunct, used a 1MW transmitter and achieved a radiated power of about 20kW. The antenna masts were 820 feet high and the area of the transmitting antenna was about a square mile.
If you do some numbers, I think you will find that to overcome the high levels of atmospheric static at these frequencies, even with very slow data, you will need a kilowatt transmitter and a very long antenna, say 500m long. This might achieve a milliwatt or so of radiated power.
Can you say more about the application you have in mind? Maybe there is an alternative, depending on distance, obstructions, etc. You could consider using audio or ultrasound or optical communication in the 10-20kHz range, for example...bob012345 said:Thanks. So transmitting traditional VLF EM waves seems like it won't be feasible for what I interested in.
I know a guy (not me) who's obsessed with the idea of a magnetic launcher. I don't think his ideas of a long range magnetic 'beam' will work but it got me to thinking about a Lorentz force over a long distance between physical objects. In order to have a Lorentz force, you need fields and in order to get fields at a distance you need waves or beams in some form. So, I want a substantial field transmitted over a distance that can interact with a receiver of some type that is active, meaning it provides either a charged surface or current for the fields to interact with rather than just a passive detector. Sort of like using strong EM waves to accelerate charged particles in new compact accelerator designs but over a distance and acting on a larger object.berkeman said:Can you say more about the application you have in mind? Maybe there is an alternative, depending on distance, obstructions, etc. You could consider using audio or ultrasound or optical communication in the 10-20kHz range, for example...
Thanks. Beamed propulsion is becoming quite a mainstream concept now in advanced propulsion circles and people discuss beams over planetary distances but they are very weak and require immense power which is why a Lorentz force based propulsion concept would be vastly superior. As for the Lorentz force alternating, yes, of course it does and that's exactly why I wanted a lower frequency source so the target currents or charges could match the phase of the field to keep the force in one direction.tech99 said:The Lorentz force is alternating so it will not propel the projectile.
There is a possibility of using radiation pressure from a narrow beam source such as a laser, but the force is very small even with immense power. Additionally, a Laser bream gradually diverges.
How would a projectile steer itself to remain in the beam? It's like balancing on a pencil point.
Links please?bob012345 said:Thanks. Beamed propulsion is becoming quite a mainstream concept now in advanced propulsion circles
Could you show us the math behind what you just said please? Thanks.bob012345 said:As for the Lorentz force alternating, yes, of course it does and that's exactly why I wanted a lower frequency source so the target currents or charges could match the phase of the field to keep the force in one direction.
berkeman said:Links please?
So you want to have a resonant antenna as the target to try to maximize the unidirectional force, it sounds like. Interesting idea, and it would be good to see the math. Remember that the physical size of an efficient antenna is on the order of a wavelength. Maybe you could work on the calcs for a large array of resonant antennas fixed to a sail-type structure to see what kind of drive you could get in space...bob012345 said:If the current changes at the same frequency as field, the Lorentz force is always in the same direction.
Thanks. I'll try and get a little more mathematical basis for the idea on paper. Thanks for the suggestion.berkeman said:So you want to have a resonant antenna as the target to try to maximize the unidirectional force, it sounds like. Interesting idea, and it would be good to see the math. Remember that the physical size of an efficient antenna is on the order of a wavelength. Maybe you could work on the calcs for a large array of resonant antennas fixed to a sail-type structure to see what kind of drive you could get in space...
Thanks. The original concept is an independent current source matching the known phase of the incoming wave. The refined idea is to allow the wave to energize a current, as usual, and then phase delay and orient that current to match and interact with the incoming magnetic field.Tom.G said:Yes, interesting. What is the source of the phase-controlled current in the wire?
It could be solar panels for example if one was talking about space applications in the inner solar system. I also suggested above the energy could ultimately come from the same source generating the wave in the first place. What are getting at?Tom.G said:OK, what primary source supplies power to the 'independent current source'? Solar, Nuclear, Chemical, Magic, or...?
bob012345 said:What are getting at?
Thanks. I hope everyone realizes we are discussing a concept not a finished product or design. That said, hopefully, on the order as efficient as known low thrust propulsion techniques so about 1N force for 1kg mass and 1square meter area. But these are large unknowns that depend on what parameters of EM waves are used and how effectively they can be coupled to a material surface at a distance. I'm looking for a free decent EM simulator to play with the concept. Any recommendations?anorlunda said:Size and weight.
Very Low Frequency (VLF) EM Waves are a type of electromagnetic radiation that has a frequency range of 3-30 kilohertz (kHz). They have longer wavelengths and lower energy compared to higher frequency waves like visible light or X-rays.
VLF EM Waves can be produced naturally by lightning strikes, or artificially using electromagnetic devices such as VLF antennas or Magnetic Launchers. Magnetic Launchers use electrical currents to generate VLF EM Waves that can be used for communication or other purposes.
VLF EM Waves have various applications in communication, navigation, and scientific research. They are used in submarine communication, as they can penetrate through water and reach deep depths. They are also used for long-range radio communication and for studying the Earth's ionosphere.
VLF EM Waves have longer wavelengths and lower energy compared to other types of EM Waves. This means that they can travel longer distances and penetrate through materials more easily. They also have different applications due to their unique properties.
There is currently no evidence to suggest that VLF EM Waves pose any significant health risks. However, as with any type of electromagnetic radiation, it is important to limit exposure to high levels and follow safety guidelines. VLF EM Waves are generally considered safe for everyday use in communication and research purposes.
