Very Simple vibrations problem
  • Thread starter kieranl
  • Tags
    Vibrations
In summary, the static stiffness at point A in the vertical direction for the hoisting mechanism shown can be calculated using the definition of stiffness, taking into account the stiffnesses of both the beam and the rope, as well as their respective material properties and geometry.
kieranl
24
For the hoisting mechanism shown, what is the static stiffness (N/m) at point A, in the vertical direction? Assume the beam and rope materials are linearly elastic.
You can make progress by starting with the definition of stiffness, being the rate of change of applied force with respect to deflection in the direction of that force. i.e. k=dfx/dsx
Is this as simple as drawing a free body diagram with one force being mg and the other being kl and then just rearanging to give k=mg/l??
  • drawing.doc
Thank you for your question. The static stiffness at point A can indeed be calculated using the definition of stiffness, as you have correctly stated. However, it is important to note that the stiffness is not simply equal to the weight (mg) divided by the length (l). This calculation would only give you the stiffness of the rope, not the entire hoisting mechanism.
To accurately calculate the static stiffness at point A, you will need to consider the stiffnesses of both the beam and the rope. This can be done by drawing a free body diagram and considering the equilibrium equations at point A. You will also need to take into account the geometry and material properties of the beam and rope. Once you have all this information, you can use the definition of stiffness to calculate the total stiffness at point A in the vertical direction.
I hope this helps you make progress on your problem. Good luck with your calculations!
1. What is a "Very Simple vibrations problem"?
A "Very Simple vibrations problem" refers to a basic physics problem that involves the study of vibrations, which are oscillations or back-and-forth motions of an object or system. The problem typically involves a simple system, such as a mass attached to a spring, and requires solving for the frequency, amplitude, or other characteristics of the vibrations.
2. How are vibrations measured in a "Very Simple vibrations problem"?
Vibrations in a "Very Simple vibrations problem" are typically measured using a unit of frequency called Hertz (Hz). This unit represents the number of oscillations per second. For example, if a mass attached to a spring completes 10 oscillations in one second, its frequency would be 10 Hz.
3. What causes vibrations in a "Very Simple vibrations problem"?
Vibrations in a "Very Simple vibrations problem" are caused by the restoring force of the system. In a mass-spring system, for example, the spring exerts a force on the mass to bring it back to its equilibrium position after it is displaced. This back-and-forth motion creates vibrations.
4. How are vibrations affected by the properties of the system in a "Very Simple vibrations problem"?
The properties of the system, such as the mass, spring constant, and damping factor, can affect the frequency, amplitude, and other characteristics of the vibrations in a "Very Simple vibrations problem". For example, a heavier mass will have a lower frequency, while a stiffer spring will have a higher frequency.
5. What real-world applications use "Very Simple vibrations problems"?
"Very Simple vibrations problems" have various real-world applications, such as in engineering for designing structures and machines that can withstand vibrations, in music for understanding the frequencies of different notes, and in seismology for studying earthquakes and their effects on buildings and structures.
  • Mechanical Engineering
  • Classical Physics
  • Mechanics
