Very tough probability question, need some help
  • Thread starter EskShift
  • Tags
    Probability
In summary, the probability that a battery will last at least another 50 hours after already lasting 180 hours is a conditional probability question, where the event to condition on is that it has already lasted 180 hours.
EskShift
The life (in hours) of a particular brand of batteries is a random variable with probability density function given by f(x) = {1/1000e^(-x/1000)}, x ≥ 0, 0 elsewhere.
If after 180 hours of operation a battery is still working, what is the probability that it will last at least another 50 hours?
Integration
Integration of the equation, which becomes [-e^(-x/1000)]
Problem is, what boundaries is it supposed to have?
I have figured out from 0 --> 180, that is a given right? Because the question states 'if after 180 hours of operation', so it must have worked up to 180 hours.
but now what? I am sure it has got to do with finding the Probability (B) | Probability (A), which is equal to Pr (A|B) = Pr (A intersect B) / Pr (B)
This is a conditional probability question: given that it has lasted 180 hours (that's the event on which to condition) you need to know the probability it will last another 50 hours.
I can provide some guidance on how to approach this problem. First, it is important to understand the given probability density function and what it represents. This function is used to calculate the probability of a battery lasting a certain number of hours, with the variable x representing the number of hours.
In order to find the probability that a battery will last at least another 50 hours after already lasting 180 hours, we need to find the area under the probability density function curve from 180 to 230 hours. This can be done by integrating the function from 180 to 230, which will give us the probability of the battery lasting between those two times.
The boundaries for the integration are the values of x, which in this case are the hours. So, the integral will be from 180 to 230. The result of the integration will give us the probability of the battery lasting between 180 and 230 hours. We can then use this probability to calculate the probability that the battery will last at least another 50 hours by subtracting the probability of it lasting less than 230 hours from the probability of it lasting less than 180 hours.
In summary, the approach to solving this problem involves integrating the probability density function from 180 to 230 hours, and then using the resulting probability to calculate the probability of the battery lasting at least another 50 hours. I hope this helps and good luck with your homework!
1. What is probability and why is it important?
Probability is the measure of the likelihood of an event occurring. It is important because it helps us understand and predict the chances of certain outcomes, which is useful in decision making and problem solving.
2. How do you calculate probability?
Probability is calculated by dividing the number of favorable outcomes by the total number of possible outcomes. This can be represented as a fraction, decimal, or percentage.
3. What is a tough probability question and how do you approach it?
A tough probability question is one that requires critical thinking and advanced mathematical knowledge to solve. To approach such a question, it is important to break it down into smaller, more manageable parts and use logic and probability rules to solve each part before combining them to find the final answer.
4. What are some common misconceptions about probability?
Some common misconceptions about probability include the belief that past events can affect the outcome of future events, and that a low probability event is impossible. In reality, each event is independent and has its own probability, and even a low probability event can occur.
5. How is probability used in real life?
Probability is used in real life in a variety of fields such as finance, sports, and medicine. It helps us make informed decisions by predicting the likelihood of certain outcomes. For example, insurance companies use probability to determine premiums, and doctors use it to assess the chances of a patient developing a certain condition.
