Solve Vibration Problem: Find m/m1 Ratio for Stationary Point A
  • Thread starter gholamghar
  • Tags
    Vibration
In summary, the ratio (m/m1) can be found by setting up and solving equations based on the forces acting on the system, using the distance of point A and the total length of the spring.
gholamghar
27
in this vibration system find ratio of (m/m1) so that (point A) would not move and will stay stationary.
point A distance from left end of spring is 0.25 of total length of spring.
all surfaces are frictionless.
the problem is in indie numbers:
here is the answer but i can not find out how the problem is solved if any
can give me an explanation about the answer i really would appreciate it.
The ratio of (m/m1) can be found using the following steps:
1. Draw a free body diagram of the system, with point A being at a distance of 0.25L from the left end of the spring.
2. Apply Newton's Second Law (F=ma) to the system, considering the forces acting on both masses m and m1.
3. Since the surfaces are frictionless, the only forces acting on the masses are the spring forces and the weight of the masses.
4. Set up equations for the forces acting on each mass, using the distance of point A and the total length of the spring.
5. Equate the spring forces and the weight forces for each mass, and solve for the ratio (m/m1).
6. Simplify the equation and solve for the ratio (m/m1).
The final answer will depend on the specific values of the masses, the spring constant, and the length of the spring. However, the general approach is to analyze the forces acting on the system and set up equations to solve for the unknown ratio (m/m1).
I would approach this vibration problem by first understanding the basic principles of vibration and equilibrium. Vibration is a result of a dynamic equilibrium between the forces acting on a system. In this case, the forces acting on the system are the weight of the mass m1 and the spring force.
To solve this problem, we need to find the ratio of m/m1 so that point A remains stationary. This means that the forces acting on point A must be balanced, resulting in a net force of zero. In other words, the weight of m1 must be equal to the spring force acting on point A.
To find the spring force, we can use Hooke's Law, which states that the force exerted by a spring is directly proportional to its displacement. In this case, the displacement of the spring is 0.25 of the total length, so the spring force would be 0.25 times the spring constant.
Next, we can set up an equation to represent the forces acting on point A:
m1g = (0.25k)(0.25L)
Where m1 is the mass of the object, g is the acceleration due to gravity, k is the spring constant, and L is the total length of the spring.
Solving for m/m1, we get:
m/m1 = (0.25k)(0.25L)/m1g
By rearranging the equation, we can see that the ratio m/m1 is dependent on the spring constant, the total length of the spring, and the acceleration due to gravity. This means that the ratio can be adjusted by changing any of these variables.
In conclusion, to solve this vibration problem and find the ratio of m/m1 for point A to remain stationary, we need to understand the principles of vibration and equilibrium, use Hooke's Law to calculate the spring force, and set up an equation to represent the forces acting on point A. By manipulating the equation, we can determine the ratio of m/m1.
What is a vibration problem?
A vibration problem is a phenomenon in which a mechanical system experiences oscillations or repetitive motions due to external forces. This can cause discomfort, damage, or failure of the system.
How can I solve a vibration problem?
The first step in solving a vibration problem is to identify the root cause, which could be an unbalanced or misaligned component, inadequate support, or resonance. Once the cause is determined, adjustments can be made to eliminate or reduce the vibration.
What is m/m1 ratio in relation to a stationary point A?
The m/m1 ratio is a measure of the mass distribution in a mechanical system. In the case of a stationary point A, it refers to the ratio of the mass at point A to the total mass of the system. This ratio can affect the stability and vibration behavior of the system.
Why is the m/m1 ratio important in solving a vibration problem?
The m/m1 ratio is important because it can help determine the natural frequency of the system, which is a key factor in vibration analysis. By adjusting the mass distribution, the natural frequency and vibration levels can be altered to solve the problem.
What techniques can be used to find the m/m1 ratio for stationary point A?
There are various techniques that can be used to find the m/m1 ratio, such as analytical methods, experimental modal analysis, and finite element analysis. The most appropriate technique will depend on the complexity of the system and the available resources and expertise.
  • Classical Physics
  • Classical Physics
