Homework Help: Vibrations and Pendelums: Work and Answer check
  1. Nov 14, 2007 #1
    I have all of the my work and answers, I would just like someone to look over what I've done and make sure I didn't fubar a step along the way. Thanks.
    31. Given: A = 1.12 mm; f = 440.0 Hz
    Find: [tex]v_{m}, a_{m}[/tex]
    Solution:
    [tex]f = \frac {\omega}{2\pi} \Rightarrow \omega = 2\pi f[/tex]
    [tex]v_{m} = \omega A \Rightarrow 2\pi (440.0Hz)(1.12mm) = 3,096 mm/s = 3.096 m/s[/tex]
    [tex]a_{m} = \omega^{2}A \Rightarrow (2\pi (440.0Hz))^{2}(1.12mm) = 8,560,184 mm/s^{2} = 8560 m/s^{2} [/tex]
    32. Given: m = 170 g; f = 3.00 Hz; A = 12.0 cm
    Find: a) k (spring constant) b) equation that describes position as a function of time
    Solution:
    a) [tex] f = \frac {\omega}{2\pi} = \frac {1}{2\pi} \sqrt {\frac {k}{m}} [/tex]
    [tex] 2\pi f^{2} = \sqrt {\frac {k}{m}}^{2} \Rightarrow (m)(2\pi f)^{2} = \frac {k}{m} (m) [/tex]
    [tex] (m)(2\pi f)^{2} = k \Rightarrow (.17kg)(2\pi(3.00Hz))^{2} = 60.4 N/m [/tex]
    b) [tex] y = (12.0cm)sin[(2\pi(3))t] \Leftarrow [/tex] This is the only one that I am having problems with. This equation is based off of another in the book, but I am not sure if I am even going in the right direction with it.
    41. Given: m = 50.0 g; f = 2.0 kHz; A = 1.8 x [tex]10^{-4}[/tex]m
    Find: a) [tex]F_{m}[/tex] b) E
    Solution:
    a) [tex]a_{m} = \omega^{2}A[/tex]
    [tex]\omega = 2\pi f[/tex]
    [tex]F_{m} = ma_{m}[/tex]
    [tex] = m\omega^{2} A^{2}[/tex]
    [tex] = m (2\pi f)^{2} A^{2}[/tex]
    [tex] = (0.05kg)(2\pi (2 x 10^{3}Hz))^{2}(1.8 x 10^{-4}m)^{2}[/tex]
    [tex] = 1421.22 N = 1.4 kN [/tex]
    b) [tex] v = \omega A [/tex]
    [tex] E = U = \frac {1}{2}mv^{2} [/tex]
    [tex] = \frac {1}{2} m \omega^{2} A^{2} [/tex]
    [tex] = \frac {1}{2}(0.05kg)(2\pi (2 x 10^{3}Hz))^{2}(1.8 x 10^{-4}m)^{2} [/tex]
    [tex] = .13 J [tex]
    49. Given: k = 2.5 N/m; y = (4.0cm)sin[(0.70rad/s)t]
    Find: [tex]K_{m}[/tex]
    Solution:
    [tex] v = v_{m} = \omega A [/tex]
    [tex]\omega = \sqrt {\frac {k}{m}} [/tex]
    [tex]K_{m} = \frac {1}{2}mv_{m}^{2} [/tex]
    [tex] = \frac {1}{2}m \omega^{2} A^{2} [/tex]
    [tex] = \frac {1}{2}m (\frac {k}{m}) A^{2} [/tex]
    [tex] = \frac {1}{2} kA^{2} \Rightarrow \frac {1}{2} (2.5N/m)(0.04m)^{2} = .002 J = 2.0 mJ [/tex]
    62. Given: L = 120 cm; A = 2.0 cm; E = 5.0 mJ
    Find: E if A = 3.0 cm
    Solution:
    [tex] \omega = \sqrt {\frac {g}{L}} [/tex]
    [tex] E = U = \frac {1}{2} mv^{2}[/tex]
    [tex] = \frac {1}{2} m (\frac {g}{L}) A^{2} [/tex]
    [tex] = \frac {2EL}{gA^{2}} = m \Rightarrow \frac{2(.005J)(1.2m)}{(9.8m/s^{2})(.02m)^{2}} = 3.06 kg [/tex]
    [tex] E = \frac {1}{2} (3.06kg)(\frac {9.8m/s^{2}}{1.2m})(.03m)^{2} = .0112 J = 11.2 mJ [/tex]
    So, that is what I've got. If someone could just let me know how I did, it would be greatly appreciated. Thanks again.
Draft saved Draft deleted
Loading...
