Vim Macros for Python
  1. Jan 18, 2009 #1
    Hi, I am trying set a macro in vim's .exrc file such that when I type # in normal mode, vim will call python3 to run my code. I edited the first line of the .exrc file (which is all i need to do i believe), however when i try to open my .py code in vim I get this message:
    ubuntu@ubuntu:~$ vim programs/name.py
    Error detected while processing /home/ubuntu/.exrc:
    line 1:
    E518: Unknown option: #
    Press ENTER or type command to continue
    Thanks in advance!
    Nick
    .exrc CODE:
    set # :!clear;python3 %
    syntax enable
    set nocompatible " use vim extensions
    " Bells
    set visualbell t_vb= " turn off error beep/flash
    set novisualbell " turn off visual bell
    " Editing info
    "set number "[same as nu] show line numbers
    set ruler "[same as ru] show cursor position
    set showmode "[same as smd] show when in insert mode
    " Search
    set hlsearch " highlight searches
    "set incsearch " do incremental searching
    " Auxilary files
    set nobackup " do not keep a backup file (ending in ~)
    set noswapfile " do not write a swap file
    " Smart editing
    set showmatch "[same as sm] highlight matching (), {}, etc.
    set nowrap " do not wrap lines
    " Tabs and Indenting
    set autoindent "[same as ai] always set autoindenting on
    set shiftwidth=4 "[same as sw] number of spaces to (auto)indent
    set tabstop=4 "[same as ts] number of spaces per tab
    set expandtab "[same as et] use spaces instead of a tab
    set softtabstop=4 "[same as sts] number of spaces to use instead of a tab
    set smarttab "[same as sta] <BS> deletes shiftwidth spaces from the start of a line
    " Syntax highlighting
    syntax enable
  3. Jan 18, 2009 #2
    mgb_phys
    I think # is a reserved word in execrc files - you generally use @ instead
  4. Jan 18, 2009 #3
    I get the same error when I try @. That can't be it.
  5. Jan 18, 2009 #4
    FIXED! should have been map instead of set
Loading...
Similar Threads for Macros Python Date
Python (VPython) Can someone help me with my orbit simulator? Monday at 12:43 AM
C/++/# If/else C Macro Jul 2, 2015
Generating Colour in Excel Cells Apr 26, 2015
Excel macro's and VBA Jul 27, 2013
Very simple macro script help (pref. AHK) Jul 20, 2011
