Voltage converter
I am bit rusty on my physics. I hope some of you can help me and check if what I have done is correct.
I have an appliance which is rated for a voltage range of 110-127 volts, drawing 4.5 amps. I would like to use it on 220 volts using a 500 Watts converter. However, I just wanted to make sure that my calculation are correct so that I don't end up smoking the appliance or the converter or both.
This is how I went about figuring it out.
Power = volts x amps
Therefore; the power rating of this appliance is between 495 Watts (110 x 4.5) to 572 Watts (127 x 4.5).
So, I have a pretty high chance of burning out that voltage converter!
Am I right?
If so, how do you figure out what is a suitable rating for a power converter for this appliance? I know that power surges temporarily when turned on/off.
Thank you all.
Answers and Replies
berkeman
Mentor
59,682
9,836
Am I right?
Thank you all.
It probably won't burn out, but the output voltage will sag and your appliance will probably not work right.
Just go with a 2x factor -- use a 1000W converter.
Related Threads on Voltage converter
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
28K
30K
