Learn About Voltage, Current & Resistance
In summary: After lots of heat is dissipated, does the Resistance, Voltage or Current change (i.e go lower or higher)?After lots of heat is dissipated, the resistance, voltage or current will most likely decrease.
Air
203
Can I have some information about these topics?
  • Voltage
  • Current
  • Resistance
  • Internal Resistance
Thank You in Advance. o:)
You need to be a little more specific.
Questions that general/vague will at best get you a reference to google or a wik link. You'll need to be more specific if you want some actual answers.
Voltage = potential difference between two points
Current = rate of change of charge with time
Resistance = proportional to the voltage and inversely proportional to current
Internal Resistance = Thevenin resistance seen by outside source
Thank You. I needed information like this. :smile:
What is Internal Resistance in relation to EMF?
Think of it analogous to water flowing from an elevated tank through a small hose.
Voltage is the pressure behind the water which corresponds to amount of water in the tank pushing down.
Current is the speed of the water.
Resistance is something in the hose obstructing the path of water flow.
Internal resistance is the resistance of the water having friction with pipe walls.
Thats a very good analogy. Thanks. :smile:
______________________________________________________
Can someone answer this question:
What do you mean by internal resistance?
Do you disagree with Mindscrape's definition?
E=IR
Well, if you have a given EMF, generated by a magnetic field changing in time, and are near some circuit or wire, you can just use good ol' ohms law to find the resistance:
V=IR, or using different notation for your EMF, EMF=IR, or R=EMF/I, so the reistance in the circuit is proportional to the strength of the EMF, and inversely proportional to current.
E=IR
The Voltage that is lost in the Power supply.
Usually, for most things, it's negligable.
For actively regulated power supplys it can be 0 or even negative.
If it is a factor, then the power supply resistance gets added to the rest of the resistance in the circuit.
Does this affect the circuit in any way?
Yes, in exactly the same way a normal resistor would. Suppose you have a cell with a 12V emf and 1[itex]\Omega[/itex] internal resistance. This would be equivalent to a circuit containing a 12V cell with no internal resistance, in series with a 1[itex]\Omega[/itex] resistor.
I see.
Is it dangerous if the resistance gets high? If so why and what happens?
Anived said:
I see.
Resistors dissipate energy, how do you suggest they do this?
Resistance serves to limit the amount of Current through the circuit with a given amount of Voltage supplied by the battery.
Yes, it does this by dissipating (removing) energy (from the circuit). This energy is dissipated as heat. Therefore, if you have a high resistance together with a high current flow, then large amounts of heat will be dissipated.
I thank all the people who have helped me so far. You have increased my knowledge. :smile:
As the temperature of a conductor increases, the resistance of that conductor also increases (note that a resistor is a conductor). Therefore, we have an example of positive feedback in a resistor; the resistance causes an increase in temperature of the resistor. This in turn increases the resistance of the resistor, thus further increasing the resistance. Therefore, the resistance of the resistor will increase.
Is it possible to have an electrical product that has Zero Internal Resistance?
Some materials are superconductors, i.e. at low temperature have a zero resistance, if that is what you mean.
No I mean the Internal Resistance which is The Resistance within a voltage source, such as an Electric Cell or Generator.
So...Can a Electric Cell be made so that it has no Internal Resistance or is it impossible?
(If you do not understand my question then please ignore it. :smile:)
No, it is not possible to create any electrical device (cell, battery, generator) with a zero internal resistance. However, in some cases where the load resistance is large compared to the internal resistance, it is possible to ignore the internal resistance.
1. What is voltage?
Voltage is a measure of the electrical potential difference between two points in a circuit. It is commonly referred to as "electrical pressure" and is measured in volts (V).
2. What is current?
Current is the flow of electric charge through a conductor. It is measured in amperes (A) and is commonly represented by the symbol "I" in equations.
3. What is resistance?
Resistance is the opposition to the flow of electric current. It is measured in ohms (Ω) and is represented by the symbol "R" in equations. Resistance is affected by factors such as the material of the conductor, its length, and its cross-sectional area.
4. How are voltage, current, and resistance related?
According to Ohm's Law, voltage (V) is equal to the current (I) multiplied by the resistance (R) in a circuit: V = IR. This means that as voltage increases, current increases, and as resistance increases, current decreases.
5. How can I measure voltage, current, and resistance?
Voltage can be measured using a voltmeter, current can be measured using an ammeter, and resistance can be measured using an ohmmeter. These devices are typically found in a multimeter, which can measure all three quantities.
  • Electromagnetism
  • Electromagnetism
