nmacholl
- 26
You want to build a voltage divider for a product that uses as it's source a 12v battery and a non-zero internal resistance. You want to have an output voltage between 4 and 5 volts. The internal resistance varies from 5 ohms when fully charged to 100 ohms when the battery is nearly dead. Create a voltage divider that meets the requirements using the smallest possible resistors (doesn't have to be real resistors). You can neglect the tolerances of the resistors and the load resistance (assume it is infinite).
http://img811.imageshack.us/img811/8537/vdivdiagram.th.gif
V=IR and Kirchoff's Rules
r is internal resistance.
R1 and R2 are the resistors necessary for the voltage divider.
RL is the load resistance (which is infinite)
12v - Ir - IR1 - IR2 = 0
If we assume infinite load resistance we can treat RL as a gap.
12v = I * Rtotal (where Rtotal is the sum of the resistances in series)
Rtotal= r + R1 + R2
From Ohm's law:
I = 12v / (r + R1 + R2)
12v - I(r - R1 - R2) = 0
12v - (12v / (r + R1 + R2))
* (r - R1 - R2) = 0
Since the voltage across R2 is equal to the voltage across RL we need I * R2 to be between 4 an 5 volts.
This is where I'm lost, specifically how do I use the internal resistance information in the problem to generate a solution that gives me 4-5volts across the load resistor?
