Voltage regulator question
c d
[mod note: thread moved from homework forum]
I have this Mouser voltage regulator
https://www.mouser.com/ProductDetail/STMicroelectronics/L7912CV/?qs=sGAEpiMZZMug9GoBKXZ75xbXFDWiKqpmvrbz5I0HaKg%3D
Wired according to datasheet https://www.mouser.com/ds/2/389/l79-974159.pdf see insert photo.
https://plus.google.com/photos/phot...0/6526650605024626690?authkey=CPTx7ezW74_OiAE
Would expect to see 12 V output. Input is 15.5 V Wired this a couple of times, get same output as input.
Before I go a lot further, am I on the right track? Your thoughts?
Answers and Replies
cd, do you have the red lead going to the negative terminal of the LiPo?
Interpreting your meter reading, is the O/P positive or negative with respect to ground?
Red goes to positive of lipo and "input" terminal (middle of three wires) of voltage regulator, thanks for asking. btw, "input" is 15.5 V [positive] with respect to ground. Reading the "output" terminal with respect to ground and getting the same...
Spec sheet calls for a C1 value of 2.2 uF for tantalum, but 10x or more when an electrolytic is used. Probably want to add a back diode across the output, too, but I don't think that's the problem. Negative regulators (more so than positive regulators) have a tendency to exhibit this symptom when under no load or lightly loaded (under 5 mA) conditions.
Why do you have the input positive with respect to ground on a negative voltage regulator?
Likes berkeman, CWatters and dlgoff
79XX series are negative regulators. From what you say i'd guess you hooked the battery backwards. Likely it's shot now.
edit - average supernova and i crossed in the mail..
Likes rbelli1 and dlgoff
The 7812 series are for +12V.
Suggested for: Voltage regulator question
