Homework Help: Voltage & Resistors
  1. Sep 16, 2009 #1
    http://img44.imageshack.us/img44/6898/83724998.png [Broken]
    How do I begin to work this kind of problem?
  3. Sep 16, 2009 #2
    I am not well familiar with the rules, but I think you should write down your attempts so that someone can help you in solving this problem.
    Hint: Use Ohm's law.
  4. Sep 17, 2009 #3
    CEL
    What are the currents through the series R1-R2 and through R3-R4?
  5. Sep 17, 2009 #4
    series r1-r2=39 k ohms
    series r3-r4=31 k ohms
  6. Sep 17, 2009 #5
    OK. Great. Now, you have the series resistance values and you know the voltage across them. You should know the current. Afterward the knowledge of the voltage across each single resistor will help in finding Vx.
    Try it. It is easy.
  7. Sep 17, 2009 #6
    But because series r1-r2 and series r3-r4 are parallel does the voltage split between them? or is that the current?
  8. Sep 17, 2009 #7
    The current is splitted between the parallel resistances and they have the same voltage. In other hand R1 and R2 are in series and the same current will flow through them. The same is true for R3 and R4.
    The current through R1 and R2 id given by (let's call it I1)
    I1 = V / (R1 + R2)
    The current through R3 and R4 can be obtained in the same way.
    As soon as you get the two currents you can find the voltage drop across R2 and R4. Now all values are known. Finally,
    Vx = V2 - V4 ( why not V4-V2; because the + sign is drawn on V2 and the - sign on V4 )
  9. Sep 17, 2009 #8
    I know this may be asking alot but can you show the math, then I can clearly see what your plugging in where. This is not my hw by any means this is the practice for the actual assignment and I'm still confused a bit.
  10. Sep 17, 2009 #9
    OK. But afterward you should do it yourself so that you deeply understand it.
    Remember that you can't make muscles looking me lift weights :) .
    I1 = V/(R1 + R2) = 0.076 mAmp
    I2 = V/(R3 + R4) = 0.096 mAmp
    V2 = I1 * R2 = 1.368 V
    V4 = I2 * R4 = 2.016 V
    Vx = V2 - V4 = - 0.645 (It is negative. What does this mean? )
  11. Sep 17, 2009 #10
    Oh okay I understand know I know that V=IR but i wasnt entirely sure what R to use. But this helps me understand. Thank you again you have been great help.
