Volume and Pressure Cylinders
  1. Feb 28, 2007 #1
    Problem comes straight from a 2001 AP Physics B test
    http://img151.imageshack.us/img151/6159/physicscylinderszq4.png [Broken]
    2. Relevant equations
    PV = nRT
    KE = 3/2KT
    deltaU = Q+W
    3. The attempt at a solution
    Okay, for the first two (a and b) I arrived at an answer of double the initial pressure of State 1 and half of the initial volume of State 1. This was because after I drew myself a little P vs. V graph, I knew the two States had to be on the same isotherm, so pressure had to increase in order for volume to decrease. Also, I just realized as I write this, if T is constant, in PV = nRT that means nRT is a constant and as P increases, V must decrease.
    I'm pretty sure that's right, if it's wrong, I would appreciate clarification.
    For c I got Isobaric, simply because isothermal and adiabatic do not work.
    For d I got Yes, 4 --> 1 is isobaric simply because I drew a P versus V graph and since it has to go back to the same isotherm State 2 was on, but volume had to decrease, it had to be isobaric.
    I do not understand e. I'm having a hardtime knowing what the weight does...do you have to use P = F/A?
    Thanks for any help at all on this, any corrections if im wrong and any elaboration on any topic is greatly appreciated.
