I Volume and Surface Charges?
  1. Aug 23, 2015 #1
    Hello,
    I know you can use Gauss' law to calculate the electric field of volume and surface charges but i cannot figure out a way to do it using Coloumb's law. I have several questions about this: when you integrate the charge density in Coloumb's law over the volume is the r^2 inside or outside the integral? is the unit vector necessary to calculate within the integral or is it allowed to drop the unit vector and obtain a scalar equation for the electric field's magnitude? Lastly, when I calculate the electric field of volume charges, i notice that after I integrate, I lose spatial coordinates with which to calculate the electric field at certain points in space.
    I am sorry for the long post but I have been struggling with this for sometime.
  3. Aug 23, 2015 #2
    blue_leaf77
    In Gauss' law the electric field in a certain point in space is a superposition from electric field due to infinitesimal charge element, The E field due to single element is the same as that due to a point charge ##k\frac{q}{r^2} \hat{\mathbf{r}}## - different charge element will have different ##r## and ##\hat{\mathbf{r}}##. This means, they are dependent on the variable of integration and hence cannot be taken outside the integral.
    That cannot be true, you should check again your calculation.
  4. Aug 24, 2015 #3
    Can somebody due an example with both Gauss' law and Coloumb's law?
  5. Aug 24, 2015 #4
    jtbell
    Staff: Mentor
    Choose an example that you tried to do, preferably one that you already know the answer for, from Gauss's law or otherwise. Write up your attempt at integrating Coulomb's law for it, and post it in the homework section (even though it's not a class assignment). Then people can tell you what you did wrong and give hints on how to proceed.
    https://www.physicsforums.com/forums/advanced-physics-homework.154/
  6. Aug 24, 2015 #5
    thank you
  7. Aug 29, 2015 #6
    Drakkith
    Staff: Mentor
    Seconded. Thread locked.
