Volume discharged
  • Thread starter badman
badman
57
A small circular hole 6.00 mm in diameter is cut in the side of a large water tank, 14.0 m below the water level in the tank. The top of the tank is open to the air.
i found the first speed
What is the speed of efflux?
16.6 m/sCorrect
now it asks me to find the volume discharged per unit time
What is the volume discharged per unit time?
Answers and Replies
badman
57
anyone, help??
Brad Barker
429
badman said:
anyone, help??
you're so close by thinking in terms of flux!
the rate of change in volume is given by the flux of the velocity of the fluid through that area.
so think how to calculate that... (unit analysis will work!) :tongue:
Doc Al
Mentor
45,412
1,848
If you have the speed through the hole and the area of the hole, you should be able to figure out the volume flow rate. Think of a tube of fluid leaving the hole. In a given time, how long would the tube be? And what would its volume be?
badman
57
nvm.........
mukundpa
524
...........Av
Suggested for: Volume discharged
  • Last Post
  • Last Post
9K
  • Last Post
9K
  • Last Post
