Volume help,
  • Thread starter tweety1234
tweety1234
112
A closed cylinder has total surface area equal to [tex] 600\pi [/tex].
Show that the volume, Vcm3, of this cylinder is given by the formula[tex] v = 300\pi-\pi r^3 [/tex],
where r cm is the radius of the cylinder.
Find the maximum volume of such a cylinder.
[tex] V= 2\pir^2 + 2\pirh [/tex]
not really sure where to start,
[tex] 600\pi = 2\pir^2 + 2\pirh [/tex]
how would I make this expression equal the other?
Thanks!
Answers and Replies
HallsofIvy
43,010
969
A, the total surface area, is [itex]2\pi r^2+ 2\pi rh[/itex], not the volume.
Yes, that is correct.
Well, first you have to decide what the "other" expression is! What is the formula for volume of a cylinder? And you don't "make them equal". Solve the equation giving surface area for h and use that to replace h in the formula giving volume.
Thanks!
tweety1234
112
Latex gone horribly wrong.
this is the question;
A closed cylinder has total surface area equal to 600π. Show that the volume, Vcm3, of this cylinder is given by the formula V=300πr−πr3, where r cm is the radius of the cylinder.
n=pi
tweety1234
112
well the formula for the volume of a cylinder = v= 2\pir^2 + 2\pirh so if I set that equal to 600\pi, what do I do after that?
tweety1234
112
so If I solve for 'h' from 600\pi = 2\pir^2 + 2\pirh I get; 300-r^2/r = h,
600\pi = 2\pir^2 + 2\pi(300-r^2)/r -----that does not simplify to the desired expression, what did I do wrong?
llauren84
44
Actually h=(300-r^2)/r not 300-r^2/r
I don't even know which formula you are trying to substitute the h in. You need to put the h in the general formula for the area of a any cylinder.
HallsofIvy
43,010
969
It looks like you have solve the area equation for h in terms of r and the replace h in the area equation! You want to replace h in the volume equation so as to get a formula for volume in terms of r only. The volume of a cylinder, of base radius r and height h, is [itex]V= \pi r^2 h[/itex].
Suggested for: Volume help,
  • Last Post
  • Last Post
  • Last Post
  • Last Post
19K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
