Why Are the Limits Different for Phi and Theta in Spherical Coordinates?
Davio
Hey guys, could one of you explain why when doing a volume integral using spherical polar coordinates, you have the limits as 2 pi to 0 on phi but only pi to 0 on theta? Thanks.
To clarify, I've been doing this all this time for questions, but it just occurred to me that I Don't know why i do that :-p.
Hi Davio! :smile:
(Of course, you can't go from o to 2π on both, because then you'd be covering every point twice!)
Well, you can always do it the other way round … but the integrals that usually occur in practice just happen to be symmetric in phi, so integrating from 0 to 2π on phi is dead easy! :biggrin:
In particular, if you're converting from (x,y,z), then you get ∫∫∫(r^2)sinthetadrdthetadphi … and that itself is symmetric in phi, so with luck the whole thing immediately becomes 2π∫∫r^2)sinthetadrdtheta. :smile:
Hmmm, but wouldn't it be, for both phi and theta, just pi to zero - ie. half each? Or am imagining this wrong :-p. R is radius, so integrating along that place, in a circle, theta and phi are both angles, just in different directions? My maths is a bit poor (not good for a physics major)!
Hi, Davio!
Take a line segment from the centre of the ball to its surface. That line segment makes the angle theta with the "z"-axis.
In order to reach ALL points on the circle with the same angle to the "xy"-plane, you rotate the line segment around the z-axis, with phi then going from 0 to 2pi.
Now, you will have covered ALL these circles (and hence all points) for theta-values going from 0 (i.e, the line segment runs along the positive z-half axis) to pi, (i.e along the negative half axis for z)
… don't ignore America …
Yup, arildno is right!
Start with a very long string, fixed at the North pole. Take the other end down the Greenwich meridian from theta = 0 to π. Now you're at the South pole.
So far so good … :smile:
Now sweep the string round from phi = 0 to π. You'll cover most of Europe and Africa and the whole of Asia and Australia.
But you'll stop at the International Date Line!
:rolleyes: What about America? :rolleyes:
One simple way to see it. Latitude goes from -90 to 90, while longitude goes from -180 to 180.
It's those blasted physicists again! They keep swapping \theta and \phi on us!
I'm going to sit down and think about the replies in a minute, I'm on to a question about conical cones now, does anyone have any good resources for understand the images behind integration? I can integrate etc, but can't quite understand the limits of weird shapes, or even normal shapes!
… painting problem …
Hi Davio! :smile:
Do you mean comical cones?
Now, they are weird! :biggrin:
But keep this in perspective … this isn't an integration problem … it's only a painting problem.
Imagine you have to program a robot to paint a sphere … do you tell it to paint from 0 to π, or 2π, for each coordinate?
If you give it the wrong instructions, it'll either waste paint or not use enough! :frown:
That's your only problem … making sure that everything is covered which should be! :smile:
