Volumes of Cross Sections with Perpendicular Planes
In summary: I am glad to hear that you solved the problem -- and more importantly, that you seem to understand the solution.In summary, the problem involves finding the volume of a solid with a circular base and semicircular cross sections. The diameter of the cross sections is in the base of the solid. The solution involves graphing the solid and adding the volume elements. The volume element is equal to (1/2) * pi * (9 - y^2) * delta y, which can be integrated from -3 to 3 to find the total volume.
akbar786
Hey guys I am new here i was wondering if anyone can help me understand this problem better
The base of a certain solid is the circle x^2 + y^2 = 9. Cross sections of the solid with planes perpendicular to the y-axis are semicircles with their diameter in the base of the solid. find the volume of the solid.
None
I cannot figure out where to start this problem. I know this will be an integral from -3 to 3 since its a circle with radius 3, but I am not sure how to proceed after that. Can anyone point me in the right direction?
It sounds like you need to know the area of half a sphere of radius 3 centred at the origin. It is a solid with a base which is a circle of this radius, further it says that cross sections of the solid are semicircles with diameter in the base, which I take to mean, having also a radius 3?
im not exactly sure..i can't figure out what the problem exactly wants i asked my teacher for a hint and he said "plot it on a xyz axis and figure out what the picture looks like and sum all the cross sections" that didnt help much though so I am still pretty confused
Your teacher gave you a place to start - by graphing the solid to get an idea of what it looks like, and then adding the volume elements. Per the rules of the forum you have to make an attempt to solve the problem before we can help.
Since the cross section is a semi circle the area would be (pie r^2)/2. And that will go inside the integral from -3 to 3. The part where i get confused is the problem says the diameter of the cross section is in the base of the solid. How do i go figure that out? I mean by lookin at it it seems like it'll be x+x or 2x but what do i do after that?
i worked the problem a little further. Since the D= 2x i would get (pie (D/2)^2)/2. So it would be (pie * D^2)/8 and diameter is 2x so that would give me pie * x^2/2. Then i get (pie * X^2)/2 and since X^2 + Y^2 = 9 is the circles formula X^2 would be (9-y^2). i pulled out pie/2 outside of the integral as a constant and integrated (9-y^2) from -3 to 3. I ended up with 18pie I am not sure if this is correct though. Any help?
The name of this Greek letter -- [itex]\pi[/itex] -- is pi, not pie.
Yes, 18 [itex]\pi[/itex] is correct. The typical volume element has a cross-sectional area of [itex](1/2) \pi x^2[/itex] and a thickness of [itex]\Delta y[/itex], so the volume of a typical volume element is [itex](1/2) \pi x^2~\Delta y = (1/2) \pi (9 - y^2) \Delta y[/itex].
The definite integral is
[tex]\int_{-3}^3 (1/2) \pi (9 - y^2)~dy[/tex]
Notice that when you get an expression for the typical volume element, you have almost the exact same thing as the integrand.
Thanks for correcting me i always say pie for some reason. This problem seemed pretty difficult but drawing it does make a lot of difference..Thanks for your help
Pie is a kind of pastry.
. Well, yes. The first thing I do in these kinds of problems is draw a sketch of the region. It's possible to work problems like this out without a reasonable visual representation, but it's much harder to do.
What is the definition of "volume of cross section"?
The volume of cross section refers to the amount of space that is occupied by a two-dimensional shape when it is extended into a three-dimensional object.
How is the volume of cross section calculated?
The volume of cross section can be calculated by multiplying the area of the two-dimensional shape by the distance it is extended into a third dimension.
What are some common shapes used to illustrate volumes of cross section?
Some common shapes used to illustrate volumes of cross section include rectangles, triangles, circles, and semicircles.
What is the relationship between cross section and volume?
The cross section of an object is a two-dimensional representation of its shape, while the volume is a measure of the amount of space it occupies in three dimensions. The volume is directly proportional to the cross section, meaning that as the cross section increases, so does the volume.
How is the concept of volume of cross section applied in real life?
The concept of volume of cross section is applied in various fields such as architecture, engineering, and manufacturing. It is used to determine the amount of material needed for construction, to design and create objects with specific volumes, and to calculate the capacity of containers and storage spaces.
