Warp Drive Speed
  • Thread starter ANarwhal
ANarwhal
59
I was reading this article today: http://news.yahoo.com/warp-drive-may-more-feasible-thought-scientists-161301109.html
and in it it states this:
With this concept, the spacecraft would be able to achieve an effective speed of about 10 times the speed of light, all without breaking the cosmic speed limit.
How did they come to the figure of 10*C? Is it a matter of energy input to speed output?
Answers and Replies
Zmunkz
34
I'm guessing they had some ideas about the material properties in the ring and the amount of curvature they might expect to get out of it. I wonder if we can find the publication on which this story is based... Might have more info.
Glad you posted this question -- that was a cool link to read!
vega12
The author of that study has actually posted in the comments here: http://www.icarusinterstellar.org/daydreaming-beyond-the-solar-system-with-warp-field-mechanics/. Looks like it is not published at the moment, so we can't see the details of the analysis. This also says how he came up with a reduced energy requirement: "the energy requirements can be greatly reduced by first optimizing the warp bubble thickness, and further by oscillating the bubble intensity to reduce the stiffness of space time". Interesting to see that something we have always thought of as a absolute physical restriction (the speed of light) can be overcome in some clever way without even appealing to a new theory (not counting the wormhole solution of course).
dcooper
Would warp drive be a external force or internal forces. Any experts please Help. -dcooper
K^2
32
Neither. The ship does not actually undergo acceleration. It's the make the mountain come to you type of deal.
HomogenousCow
736
210
how do we define the speed anyways??
Zmunkz
34
I never quite understood that. Where is the equal-and-opposite-reaction felt? Forces must be involved, at least around the bubble where spacetime is forced to curve. Or is it more like a wave in water and the forces are between the parts of spacetime itself?
But even in that case, wouldn't you at least experience a strong tidal and gravitational pull as the spacetime beneath you became arched between the front and back of the bubble?
HomogenousCow
736
210
Are we really taking this seriously...
K^2
32
Local or global? There is a huge difference, which is why this thing works at all. Local speed is limited to c. Global is not.
Absolutely. I mean, it only works on paper so far, but it's based on General Relativity, and that stuff has been verified to 11 orders of magnitude. So it's probably right. Or at least, precise enough for this to work.
Note, this is still note technologically feasible, and whether it ever will be is an open question. The new computation just bring us one step closer.
Again, the craft does not accelerate. There are no forces. You might need to have some velocity relative to destination point, which would be achieved with conventional rockets. But the warp drive itself does not provide a force of any kind.
The space-time inside the bubble is flat. No tidal forces either.
Edit: Though, I have no idea what happens to interstellar dust in all of this. I don't know if anybody tried making computations that account for it.
Nugatory
Mentor
14,115
7,881
Here's a question:
Suppose, for the sake of argument that this line of thinking eventually enables us to transport a massive object, say a message written on a piece of paper, or a bomb, or a person, or whatever between two points in spacetime that are spacelike separated. (If we can't do this, it's not an especially cool and interesting "warp drive":smile:).
What good paradoxes can we construct under this assumption?
My personal definition of a good paradox: A good paradox will be short and easily described (think bug-rivet or pole-barn), will conflict strongly with our intuition of what is physically reasonable ("Hey - I just killed my grandfather!"), and will tell us something interesting when we've resolved it (think Bell's spaceship).
sophiecentaur
6,328
I think they may well be.
I think an eye of newt and toe of frog may be called for soon. :wink:
K^2
32
No true paradoxes, but there might be some interesting things that seem like paradoxes. Though, pole-barn paradox is in the same category, so that's probably what you are thinking of.
The biggest conceptual "problem" with FTL travel is that it violates causality. Causality is a local concept in GR, which is why Warp Drive can exist, but it's a bit hard for people to wrap their mind around global causality violations.
Look at the same pole-barn paradox. It seems like a paradox because order of events appears to switch. But in order for this to happen, the two events must be space-like separated. In other words, closing of the first barn door cannot be the cause of second door opening. If you rig the second door to open only after the first one closed, the pole will ram into the second door in every frame, because the signal required to open the door has not had time to propagate. This is effectively how pole-barn paradox is resolved. Yes, order of events is frame-dependent, but effect always follows cause in every frame.
But if instead of the light beam signal from first door to second I send information with a tiny warp drive ship, the information can actually arrive in time. I can have the second bar door open as response to first door closing, and do so in time for the pole to go through. Now the situation becomes truly bizarre from pole-bearer's perspective. He knows that the second door will only open after the first one closes, but he observes the second door opening before the first door closed. The effect precedes the cause.
That's the sort of "paradoxes" that we can expect with a warp drive.
Notice that these still don't cause any real contradictions. Yes, causality is a frame-dependent concept now. But even though there is a frame of reference in which you can have results of the lottery drawing before the drawing took place, there is no way to make use of that information.
Of course, GR also allows time travel, so apparently, knowing results in advance and being able to act on it would not be a problem either. But that's a separate discussion all together.
Nugatory
Mentor
14,115
7,881
Well, I was kinda hoping for a true paradox, a genuine logical inconsistency that would spare us the search for Sophiecentaur's "eye of newt and toe of frog".:smile:
K^2
32
There aren't any. GR allows for space-time configurations that allow exceeding speed of light. GR is a self-consistent theory, so there cannot be any true paradoxes from that alone.
It's a different question of whether any of these things are practically achievable. Original Alcubierre Drive requires negative energy densities. I have no idea if this issue was ever resolved. But if not, that's the biggest hurdle. It might make Warp Drive an impossibility despite being entirely consistent with all other physics.
Edit: Though, GR solutions for closed world lines do exist with positive energies only. And if you can time-travel, you can FTL travel.
mrspeedybob
869
65
Does it require absolute negative energy density or can the energy density be negative relative to an arbitrary zero? For example, if I fill a chamber with ambient radiation, then somehow exclude that radiation from certain regions, will the excluded regions function as negative energy regions for the purposes of building an Alcubierre drive that carries somethi across the chamber?
K^2
32
I believe it would suffice. In fact, it seems that hopes of achieving negative energies in vacuum lie in finding ways of lowering vacuum energy locally. Casimir Effect is a favorite for that. This note in Wikipedia article on the effect comes with some references.
The solutions I've seen for traversible wormholes do, in fact, require negative energy densities same as Alcubierre Drive. So it would seem that the energy just has to be negative relative to the energy of the surrounding medium. Keep in mind that I'm not an expert on GR, however. I can do the math on the level required to show that Alcubierre Drive works in principle, but that's about it.
It's also worth nothing that predictions of vacuum energy based on RQFT and on measurements of cosmological constant disagree by something like 100 orders of magnitude. There is some good recent evidence that [itex]<q\bar{q}>[/itex] condensate should be excluded, but that still only brings down the error to something like 20 orders of magnitude. That suggests that there might be something important we are missing in underlying physics that leads up to Casimir Effect.
Zmunkz
34
It's not a true paradox, but the Fermi Paradox comes into play if this drive can be built. I suppose that's evidence against the likelihood of actually being able to construct it...
K^2
32
Or just limitations. I mean, even if 10c is achievable with this, it gives us practical access to maybe a few thousand stars. Odds of none of them having a civilization advanced enough for a visit over the past few thousand years are actually pretty high, even if we assume that Earth's evolution is fairly typical.
d3mm
140
I read the original article way back when. The 10c is a result of bad journalism.
The guy (Harold White) was using an arbitary example to explain it. He says something like, "if you were going at 0.1c and had a (multiplier?) of 100, your ship would be going at 10c"
Somehow the press interepreted that as warp drives traveled at 10c.
I will try to find the original article.
edit: I found it.
Within the shell thickness of the warp bubble region, the spacecraft never locally breaks the speed of light and the net effect as seen by earth/ship observers is analogous to watching a film in fast forward. Consider the following to help illustrate the point – assume the spacecraft heads out towards Alpha Centauri and has a conventional propulsion system capable of reaching 0.1c. The spacecraft initiates a boost field with a value of 100 which acts on the initial velocity resulting in an apparent speed of 10c.
The source is here, in Harold White's paper
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20110015936_2011016932.pdf
Science journalists - can't live with them, can't live without them
K^2
32
Anything you track down that's closer to original than what goes into press would be great. I was trying to find some conference papers, or something, but haven't been successful.
d3mm
140
See the edit
cragar
2,552
you say maybe a few thousand stars, does this include time dilation.
Couldn't we get to a bunch of stars at .9c when we factor in time dilation.
Cause our clock is running slow.
K^2
32
Accelerating to .9c is very, very difficult. It takes a huge amount of energy to maintain it as well, because of all the interstellar dust. I don't know if warp drive actually helps with that, though.
d3mm, thanks for the link.
HomogenousCow
736
210
plenty of things can be observed to be moving at superluminal speeds
Zmunkz
34
Note that time dilation does not occur for warp travel, so any accounting we do down this line of thought considers conventional propulsion explorers only.
K^2
32
I'd have to take a look at the metric a bit more carefully, but I'm pretty sure some time dilation will occur with warp drive. It can be made arbitrarily close to unity with stronger "warp field". But I don't think it can be reduced exactly to unity.
d3mm
140
It's making a theoretically testable prediction, and not violating any existing theories (well maybe a few but nothing seemingly fundamental)
Why would it not be taken seriously?
Nugatory
Mentor
14,115
7,881
You sure about that?:biggrin:
Zmunkz
34
If this is within your capabilities I would be very interested to hear your full analysis. I went back to the Wikipedia article, from where my statement came, and found that particular claim is lacking a citation and may well be in error.
  • #31
sophiecentaur
6,328
The bottom line is surely the question of whether the Warp Field has ever actually been observed or generated. Everything I read seems to start, basically, with the word "if". It there anything I could read which starts with "we have done the following"?
  • #32
K^2
32
It certainly is within my capabilities, since the metric is completely defined, but the algebra might get messy. I'll take a look at it. Maybe I can make Mathematica do bulk of the work for me.
Geenral Relativity is a bit like Evolution. Experiments we can do in the lab to confirm them are very limited, but observational evidence is so overwhelming that everyone believes that they work.
On one hand, there are a lot of predictions of GR that people take to be true without any evidence simply because they believe in GR. Gravitational waves have not been observed. Neither has any of the crazier physics related to black holes. But when GR explains to 11 decimal places something that happens to a remote pulsar that according to classical physics shouldn't be happening at all, it's difficult not to believe in GR's predictions.
Fortunately, this is one of the few cases where we can see an actual result before we are anywhere near ability to do this on true scale. If the interferometry experiment works out, we'll have confirmation that the effect exists, even if we aren't certain in its magnitude.
  • #33
sophiecentaur
6,328
I guess we need to watch this space.
I must admit, though, that I find it troubling that a fanciful TV series can generate so much 'belief'. The followers of Start Trek are mostly totally irrational (as with all entertainment fans) so Star Trek topics ring bells with me.
I am sure that people really do believe in dilithium crystals too!
  • #34
K^2
32
It has nothing to do with Star Trek except for the name. Somebody called it a "warp drive" after the one in the show, and the name stuck.
Alcubierre drive is a serious mathematical model motivated by our best understanding of physics of space-time. Its author, Miguel Alcubierre, is current director of Nuclear Sciences Institute at UNAM. And while the drive itself is entirely hypothetical, the physics behind it is General Relativity, which is one of the most successful scientific theories ever.
Alcubierre drive, as originally stated, has serious limitations. This new research will significantly improve on that. There might be some error in these new adjustments. That remains to be seen. But the principle of what we call a Warp Drive is absolutely solid.
  • #35
sophiecentaur
6,328
OK. I am very relieved. But it shows the power of 'the icon' in our personal view of the world. I should have known better, when so many reputable PF contribs were taking it all so seriously.
Suggested for: Warp Drive Speed
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
