• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Water density and temperature
  • Thread starter jazzchan
Dear all
Here is a question i need to help
Can I know how much water at 25^C to put into a water at 75^C and then the mixture is 60^C ??
thanks and best regards
Jazz
VietDao29
1,417
Use
[tex]Q = mc\Delta t[/tex]
Viet Dao,
is it mean the Q of temperature from 75 to 60^c is equal to the Q of 25 to 60^C ??
thank
HallsofIvy
41,683
865
Since we are dealing with water of a constant heat capacity, it's not the complicated. You can treat it as a "mixture" problem. If you have x cm 3 of 25 degree water, the heat is proportional to 25x. If you have y cm3 of 75 degree water, the heat is proportional to 75y. Mixing those together you have x+ y cm3 of water that you want to be 60 degrees so the mixture's hear is proportional to 60(x+y). You want 25x+ 75y= 60(x+y). Of course, that's one equation in two unknowns because you didn't say how much of the 25 degree water you had or how much water you wanted to end up with.
yes...my question is to find how much 25 degree water should be used...
would u tell me more ??
thanks...
Related Threads for: Water density and temperature
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
