• Support PF! Buy your school textbooks, materials and every day products Here!
Water equilibrium
Hi,
I must calculate how much CO2 has to be removed from the water (pHs=7.2) to obtain equilibrium
Given concentrations:
HCO3-: 223 mg/L
CO2: 60 mg/L
pH: unknown
SI: unknown
What is meant by equilibrium? (ph=7?) Please advise how to tackle this problem
Answers and Replies
Bystander
1,162
There are missing parameters: temperature, pressure, other solutes. Check the problem statement and see if isn't referring you to something previously mentioned.
Borek
Mentor
28,328
2,716
My bet is that they want you to assume concentration of CO2 is equivalent to the concentration of H2CO3. Then it is just a matter of treating the solution as a buffer, finding the required final concentration of carbonic acid, and comparing it with the initial (60 mg/L) CO2 concentration.
Sorry, I forgot to mention that this is a water treatment problem. Temperature is 12C.
What formula is applicable?
Borek
Mentor
28,328
2,716
Acid dissociation constant definition, or Henderson-Hasselbalch equation (which is actually the same, just rearranged to a more convenient form).
Well, after some research I came up with this, what do you think?
pHs = 7.2 = equilibrium of CO2 (= H2CO3 ) and HCO3-
pHs = pK1 – log ([CO2] / [HCO3-])
pK1 = 6.45 @12C
log ([CO2] / [HCO3-]) = -0.750
log ([CO2] / [HCO3-]) = 0.178
[HCO3-] = 223/61 = 3.656 mol/L
[CO2] = 0.178 * 3.656 = 0.650 mol/L
CO2 = 0.650 * 44 = 28.6 mg/L
We need to remove 60 – 28.6 = 31.4 mg/L
Borek
Mentor
28,328
2,716
Actually I did a mistake reading the original question, and it doesn't make sense to me now. Sorry about that. I missed the part about initial pH being 7.2. If teh initial pH is 7.2 and you are asked to change the pH of the solution to 7.0, you have to ADD acid, not remove it from the solution.
However, if you use concentrations given to calculate pH (which I did) you will find that pH of the initial solution is around 6.8, not 7.2.
Youdon't mean a log here, but OK.
223 mg, not g. Besides, don't ignore units, as you force others to guess what is 61.
Sorry for my typo's in the units. The question as I understand it is to obtain Carbonic acid equilibrium given the equilibrium pH = pHs = 7.2
Then:
pK1 = 6.45 @12C
[CO2] / [HCO3-] = 0.178
[HCO3-] = 223/61 = 3.656 mmol/L
[CO2] = 0.178 * 3.656 = 0.650 mmol/L
We need to remove 60 – 28.6 = 31.4 mg/L. Do you think this is correct?
Borek
Mentor
28,328
2,716
At least logic behind looks OK, I have not checked the exact value (but it is definitely in a correct ballpark).
Hi Borek,
That calculation was correct!
many thanks for your assistance.
One more question, how do I calculate this one?:
Lime (calcium hydroxide) is used in softening. How much lime (mmol/L) needs to be dosed in the softening step?
Borek
Mentor
28,328
2,716
Please start another thread (and follow the template).
Related Threads for: Water equilibrium
  • Last Post
22K
  • Last Post
