nat558
- 3
For stirred, maintaining temperature at 80 and at atm pressure
thx ..
thx ..
redargon said:heat of vapourization of water is 40.65 kJ/mol. See if that helps.
Also; how much water? How fast are you stirring? Surface area of the water? 80°C or 80°F
my pleasure ..
The water evaporation rate at 80°C, 1 atm refers to the rate at which liquid water changes into water vapor at a temperature of 80°C and a pressure of 1 atmosphere (atm). This process is known as evaporation.
The water evaporation rate at 80°C, 1 atm can be affected by several factors such as the temperature and pressure of the surrounding environment, the surface area of the water, the humidity of the air, and the presence of other substances in the water.
The water evaporation rate at 80°C, 1 atm can be measured using various methods such as the weight loss method, the wet bulb-dry bulb method, and the gravimetric method. These methods involve measuring the amount of water that has evaporated over a certain period of time.
Studying the water evaporation rate at 80°C, 1 atm is important for understanding the process of evaporation, which is a key part of the water cycle. It also has practical applications in industries such as agriculture, where evaporation rates can affect crop growth, and in engineering, where it is important for designing efficient cooling systems.
The water evaporation rate at 80°C, 1 atm is just one specific condition in which water can evaporate. At different temperatures and pressures, the rate of evaporation can vary significantly. For example, at higher temperatures and lower pressures, the evaporation rate will generally be higher.
