Water force through weight
gerrywelshman
Hi All,
If I have a tank 1meter dia 5metres height and a tank 200mm dia (1/5 size ) 5metres high
and I have a horizontal tap at the bottom of each. when I open the taps will I get more distance
of water from the bigger tank.
Answers and Replies
BiGyElLoWhAt
119
Have you tried figuring out the pressure? (Force/ unit area) If the pressures are the same, then you will get the same, if one is larger, it will shoot the water further out of the tap.
gerrywelshman
Hi BiGyElLoWhAt, (some handle that)
I have been interested in a design feature.
Thanks for clarifying a discussion I've had lately .
I had been told the water would shoot out the same distance.
BiGyElLoWhAt
119
That very well may be, but I wouldn't be so sure without making the calculation. If you look at a cross section of the water, then the pressure on the water below it would be the weight of the water above that cross section divided by the area (pi*r^2).
If you're looking at something of the order of 200mm diameter, then the adhesive properties of water would become non-negligible, in my opinion.
pbuk
2,128
That's a helpful answer.
And that's not. Pressure in a tank is only dependent on depth, not the size or shape of the tank.
And that's just irrelevant.
Perhaps the best answer is: look up Torricelli's Law.
Likes davenn
BiGyElLoWhAt
119
...Pressure in a tank is only dependent on depth, not the size or shape of the tank...
I understand that the cross section divides out from the volume, giving a depth dependant function. My purpose was to get the OP to do the calculation and figure it out. Good Job.
BiGyElLoWhAt
119
Also, adhesion is not irrelevant for small enough containers.
DaveC426913
4,440
That's an 8-inch diameter cylinder. Water adhesion might be relevant to the OP's education, but surely not to this application.
Likes BiGyElLoWhAt
BiGyElLoWhAt
119
Very true. Not sure how I grossly underestimated that, but...
Suggested for: Water force through weight
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
