- 6
Suppose the water fountain in fountain hills, Arizona, rises 150ft above the lake. Neglecting wind effects and minor losses, determine the velocity at which the water is ejected
yes, i tried using this formula, but i dont know if its rightdid you make an attempt at this problem?
yes thats what i meant. is the steps i used in the above right?I assume what you mean is that water is squirted directly upward so it reaches a peak 150 ft above the jet where it exited. If that is the situation, it is the same as shooting a projectile straight up.
Nope, the initial velocity is not right. The water rises up to 150 ft. What does this tell you?yes, i tried using this formula, but i dont know if its right
V^2 = Vo^2 + 2AD
A = 9.8m/s^2
V^2 = 0^2 + 2(9.8)D
V^2 = 19.6D
V^2 = Vo^2 + 2AD
A = 9.8m/s^2
V^2 = 0^2 + 2(9.8)D
V^2 = 19.6D
So it should be like thisNope, the initial velocity is not right. The water rises up to 150 ft. What does this tell you?
..and also, the given unit is ft. Then, g = 32 ft/s/s
Well, gravity drags the "projectile of the water" down. Consider throwing up the ball for example. If you toss the ball, then you exert the initial velocity v_0. At the highest point (or at the max height), the ball stops rising. That means v = 0 ft/s or v_f = 0 ft/s. After that time, the ball falls down due to gravity.So it should be like this
V^2 = Vo^2 + 2AD
A = 32 ft/s
V^2 = Vo^2 + 2(32)150
then what is the value fo V^2
