1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Water Jet Reaction Force
  1. Oct 21, 2015 #1
    Hi all,
    my first post on here and just wanted to check something I'm working on for a project.
    The project is to use a pump to create a jet of water to manouvre small boat.
    I have found a formula to work out the jet reaction force in a fire fighting text book which gives:
    R = 0.157 * P * d^2 where R = Reaction force in Newtons
    P = Pressure in bar
    d = nozzle diameter in mm
    To avoid buying and testing different pumps and nozzles empirically to find the best reaction force I wanted to link a given pumps flow and pressure to find nozzle diameter and then using this and the pressure and the above formula to get the reaction force.
    I have been using
    L = 2/3 * d^2 * sqrt P where L = flow l/min
    P = pressure in bar
    re-arranged to give
    d = sqrt (L/ (2/3 * sqrt P))
    this gives d in mm then putting this and the same pressure back into the above reaction formula to get reaction in Newtons.
    as an example:
    a pump giving P = 1.52 bar
    Q = 450 l/min
    d = sqrt (450/ (2/3 * sqrt 1.52))
    = 23.4 mm
    R = 0.157 * P * d^2
    = 0.157 *1.52 *23.4^2
    =130 N
    Are the formulas i'm using valid? If so could someone show me how to get to them from first principles or just tell me they're ok :) If not then why?
    Other losses: I have thought about losses due to pipe work friction but if the nozzle is underwater what sort of losses could I expect due to reduced flow because of higher pressure at/just after outlet
    Thanks in advance for any help.
  3. Oct 21, 2015 #2
    Andrew Mason
    Welcome to PF acebaraka!
    You could try using: F = dp/dt = d(mv)/dt = v(dm/dt) + m(dv/dt). If the speed of the water jet is constant (ie. dv/dt=0), the force is given by f = v(dm/dt) where v is the speed of the water exiting the nozzle and dm/dt is the mass flow rate out of the nozzle. The mass flow rate is the volume flow rate x mass/unit volume of water (1 kg/l).
    You can determine the speed of the water using Bernoulli's principle: ##\Delta \frac{1}{2}\rho v^2 = -\Delta P## (the change in kinetic energy per unit volume is equal and opposite to the change in pressure).
  4. Oct 21, 2015 #3
    Thanks for your reply, do I have this right ?
    delta P would be:
    system pressure at or just before the nozzle - (for the sake of ease at the moment) atmospheric pressure
    which would be 1.52bar but in SI
    so SqRt (P / (0.5*density)) would give v
    v = SqRt (152000 / (0.5*1000))
    =17.43 m/s
    F= v * (dm/dt) for 450l/min (dm/dt) = 450/60 = 7.5 kg/s
    = 17.43 * 7.5
    = 130N
    which rather wonderfully comes out to the same as what I had with the other equation, to good to be true? :)
  5. Oct 21, 2015 #4
    Andrew Mason
    Not at all. I expect that the formulas you had were derived the same way.
