paweld
- 255
Is it true that the line of coexistence of water vapour and ice starts from
the point p=0, T=0?
the point p=0, T=0?
A water phase diagram is a graph that shows the relationship between temperature, pressure, and the physical state of water (solid, liquid, or gas). It illustrates the conditions under which water can exist in each phase.
Vapour-ice coexistence refers to the simultaneous existence of water vapour and ice at a particular temperature and pressure. This indicates that the water is at its melting point, where both solid and gas phases can exist in equilibrium.
No, it is not possible for water to exist in both phases at 0 Kelvin (absolute zero) and 0 Pascals (vacuum). At these extreme conditions, water would exist only as a solid (ice) and cannot exist as a gas (vapour).
The water phase diagram provides information about the properties of water, such as its melting point, boiling point, and critical point. It also shows the conditions under which water can exist as a solid, liquid, or gas, and how changes in temperature and pressure can affect these phases.
The water phase diagram is important because it helps us to understand the behaviour of water under different conditions. It is also used in various fields, such as chemistry, meteorology, and engineering, to predict and control the physical states of water in different environments.
