Homework Help: Water Pipe Flow
  1. May 6, 2012 #1
    If water flows through a pipe at 0.8m/s , how many litres will flow through the pipe in 1 hour?
    I think I may be greatly overthinking this question, I keep thinking I need to take into the account of the trench length which is 500m, and the pipe size which is 0.5m diameter.
    Should I just m^2 * m/s = m*m*m / s = m³/s
    2. Relevant equations
    Pipe diameter: 0.5m
    Trench length 500m (if relevent)
    3. The attempt at a solution
    I am just assuming the answer is:
    0.8 x 60 = 48
    48 x 60 = 2880
    Therefore the answer is 2880m in an hour.
    But im not sure how to convert this to litres.
    Should I use the velocity 0.8m/s and use dimensions?
    Sorry, such an easy question that has confused me!
  3. May 6, 2012 #2
    LCKurtz
    The length of the pipe has nothing to do with it. Given that the pipe is circular, wouldn't you expect ##\pi## to appear in the answer? Think of a circular slab of water that exits the pipe in 1 second. What would its volume be? That should get you started.
  4. May 6, 2012 #3
    0.5pie x 0.8
    =0.16 cubic metres/s
    x 120
    576l/hour
  5. May 6, 2012 #4
    FYI, there are 1000 litres in a cubic metre.
    What is the area of the pipe cross-section?
    Using that, what length of pipe holds one litre?
