Calculating Water Pressure in a Half-Full Sphere: A Simple Explanation
In summary, the pressure of water in a sphere is primarily due to the weight of the liquid and the area of the sphere. If the sphere is airtight, the pressure in the middle of the sphere is about half of the pressure at the bottom. If there is a valve that allows air pressure to equalize inside and outside the sphere, the average wall stress can be estimated.
ChessEnthusiast
115
I've been wondering how I can find the pressure water exerts on a sphere it's in.
As for cyllinders and pyramids, and prisms - the thing is extremely easy - you just take the one formula and put in numbers.
What about a situation when we have a sphere whose radius is R, and it's half full with water.
Could you explain to me in simple terms how to find this pressure?
If it's not possible to explain it in an easy way, then please use calculus.
What's in the other half of the sphere? Air? That's going to matter a lot.
Try to list out all the parameters that you think might be important.
Since fluid pressure does not depend on the container shape, I'm curious as to what that "one formula" is and how you are or aren't using it...
Khashishi,
Yes, it's air.
I think that this pressure will depend on the radius of the sphere, the density of the liquid that is in the sphere and the weight of the liquid.
russ_watters,
The formula I've been using is this one:
[tex]p = \rho gh[/tex] , where [tex]\rho[/tex] is the density of the liquid.
What about the pressure of the air?
[tex]p = \frac{m_{water}g}{2\pi R^{2}} +\frac{m_{air}g}{2\pi R^{2}} [/tex]
Is it close to any extent?
Many errors there.
Air pressure doesn't work like that. Take a look at the ideal gas law.
Why did you change ##h## in your equation to ##\frac{1}{2\pi R^2}##?
It's not even clear if you are asking the right question. Are you looking for the wall stress? That's not the same as the pressure.
Khashishi said:
Many errors there.
Pressure = Force / Area, thus I assumed the force we need to take into consideration is the weight of the water in the sphere and the area is half of the sphere's area.
And yes, I am looking for the wall stress. Sorry for having confused you with pressure.
Is this a real world problem? (Is this a problem on Earth?)
If your sphere is airtight, then you could have a different air pressure inside and outside the sphere. In which case, the difference in air pressure is probably going to be the dominant source of pressure, unless your sphere is quite large (so that the water is quite deep inside the sphere). For instance, (Earth) surface air pressure is equal to the pressure of about 10 meters depth of H2O (assuming Earth gravity). So, if your sphere is 20 meters tall, and half filled with air at surface pressure, then the pressure in the middle of the sphere is about half of the pressure at the bottom (under 10 meters of water).
Now, if you have some kind of valve that allows air pressure to equalize inside and outside, then you can mostly ignore the air for the purposes of calculating sphere wall stresses, because the internal and external pressures cancel out. The water pressure at any point in the sphere is just ##\rho gh## where ##h## is the depth of the point below the surface.
The average wall stress can be estimated by integrating over the 3/2 times the pressure of the interior over the full volume of the sphere, and then dividing by the volume of the wall. The wall stress is larger than the interior pressure, because there is tension in the wall.
See also https://en.wikipedia.org/wiki/Cylinder_stress#Thin-walled_assumption
edit: you have to multiply the pressure by 3/2, since the pressure is force in 3 directions, and the wall tension is mainly in two directions.
Likes ChessEnthusiast
So, for the case where air pressure cancels out, we have
##p = \rho gh##
Integrate over volume by cutting the sphere into horizontal slices. The slice at depth ##h## has a volume of ##\pi h^2 dh##
##\frac{3}{2} \int p dV = \frac{3}{2}mg \int_{-R}^{0} \pi h^2 (-h) dh##
##=\frac{3}{8} \rho g \pi R^4##
Now divide by volume of the wall, which is just ##4\pi R^2 t##, where t is the thickness.
##\sigma = \frac{3}{32t} \rho g R^2##
where ##\sigma## is the average wall tension.
Thank you, Khashishi.
You have solved my problem entirely.
Sorry but there seem to be some serious flaws in this analysis .
Perhaps @Khashishi would like to have another look at the problem ?
I agree. This looks to me like the OP is looking for water pressure in the tank. It's just air pressure plus hydrostatic pressure.
Khashishi,
Yes, it's air.
Why do you think pressure depends on geometry for a sphere if it doesn't for other shapes?
[/quote]
russ_watters,
[tex]p = \rho gh[/tex] , where [tex]\rho[/tex] is the density of the liquid.[/QUOTE]
That is the correct formula. You just need to add the air pressure over the water, if applicable.
In post 8 they said they want the wall stress.
Nothing of what the OP said implied he needed wall stress until that, and they didn't volunteer it, you did. Since you are the one who introduced the term and the OP seemed pretty clear to me to be about fluid pressure, I'm not convinced the OP knows what "wall stress" means. They are very different things, but I could see someone unfamiliar with the term incorrectly thinking that the pressure exerted against the wall is "wall stress".
What is water pressure in a sphere?
Water pressure in a sphere refers to the force exerted by the weight of the water on the walls of a spherical container. It is the result of the weight of the water pushing against the walls of the sphere due to its own gravity.
What factors affect water pressure in a sphere?
The water pressure in a sphere is affected by three main factors: the depth of the water, the density of the water, and the acceleration due to gravity. As the depth and density of the water increase, so does the water pressure. The acceleration due to gravity also plays a role in determining the strength of the water pressure.
How is water pressure in a sphere calculated?
The formula for calculating water pressure in a sphere is P = ρgh, where P is the pressure, ρ is the density of the water, g is the acceleration due to gravity, and h is the depth of the water. This formula can be used to determine the water pressure at any given depth within the sphere.
What are the units of measurement for water pressure in a sphere?
The most common unit of measurement for water pressure is pounds per square inch (psi). However, other units such as pascals (Pa) and atmospheres (atm) can also be used to measure water pressure in a sphere.
Why is understanding water pressure in a sphere important?
Understanding water pressure in a sphere is important in a variety of industries, including engineering, construction, and diving. It can also help us better understand how water moves and behaves in different environments, such as oceans and lakes.
  • Mechanics
  • Thermodynamics
