Water pressure problem
  • Thread starter dmk90
dmk90
Water flows through a hole at the bottom of a tank that is filled to a height h=3m. The radius of the hole is r1 = 1.5 cm.
1. What is the speed of the water immediately after it leaves the hole?
2. At what distance d below the bottom of the tank is the radius of the stream reduced to r2 = 1 cm?
I managed to solve the speed for 7.7 m/s. However, I'm not sure what formula to use to address the atmospheric pressure that cause the stream to shrink.
Answers and Replies
5,025
The stream shrinks because it is accelerating gravitationally. As it speeds up, for the flow rate to remain constant, the cross sectional area must decrease.
Chet
dmk90
Based on your clarification, I calculated the velocity at the bottom using the conservation of volumetric flow rate (R = Av = constant), v0 = 17.3. Then g = dv/dt -> dt = dv/g = 0.98 s. Then d = d0 + v0t + 0.5at2 = 12.3, which seems to be the correct result. What do you think?
5,025
I haven't checked your arithmetic, but you seem to have the right idea.
Suggested for: Water pressure problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
