TFM
- 1,026
If a tap is turned on gently to give a continuous stream of water, the column of water tapers (i.e. the width of the column decreases) as is falls. Explain this observation. Show that the cross-sectional area, A, of the column at a point P below the mouth of the tap is inversely proportional to the velocity of the water at P.
For the first part, I have written:
"The water tapers because when the water leaves the tap it has a constant velocity, but as it falls down, gravity accelerates the water. This means that the water at the bottom is going faster than the water at the top. Since the amount of water is constant, the water increases its density and makes itself have a smaller volume as it falls down, meaning that the bottom is thinner then the top."
What I am not sure of is the second part:
What I have written kind of agrees, the cross-sec. area at the top, where it is slowest, is greater then the cross-sec. area at the bottom, where it is fastest, but I am not sure how to prove it.
Any suggestions?
TFM
