Water vapor Thermodynamics
50
How much water vapor (100 ° C) should be added to 120 g of ice (0 ° C) so that the final system has a final temperature of 35° C.
2. Relevant equations
Qvapor = lvapor * mvapor during condensation, where lvapor =2260 kJ/kg
Q1 = cwater*mvapor*ΔT during cooling, and cwater = 4,19 kJ/kg
Qmelting =lmelting * mice during melting, and lmelting =333 kJ/Kg
Q2 = cwater*mice*ΔT during heating
3. The attempt at a solution
Energy which is emitted by the vapor is given by: Qvapor + Q1 = 2260m + 4,19*m*100
Energy taken up/used by the ice is given by: Qmelting + Q2 =
333*0,120 + 4,19*0,120*35
I then set energy emitted = energy taken up by the ice and solved for m
2260m + 4,19m*100 = 333*0,120 + 4,19*0,120*35
m= 0,0215 kg or 21,5 g.
Do you think this is the correct way to solve this problem?
DrClaude
Mentor
6,372
2,625
Your approach is correct, but your numbers are not:
50
Ok. I don´t see which number could possibly be wrong? The temperature change is + 100 degrees, 4,19 kJ/kg is cwater, and 2260 is lvapor (according to my somewhat dated textbook).
50
I tried calculating m using both -100 degrees and +135 degrees, and still got the wrong answer.
DrClaude
Mentor
6,372
2,625
Don't plug in numbers randomly.
What does ##\Delta T## stand for in the equation ##Q = c m \Delta T##?
50
ΔT stands for Tfinal - Tinitial, but using Tfinal = 35 and Tinitial= 100 gives a ΔT = -65, and a m = 0,0289 g, which is also the wrong answer.
BvU
11,557
2,494
Could it be you forgot the 4,19*0,120*35 ? Or the 4,19*m*65 ? My guess: the latter!
DrClaude
Mentor
6,372
2,625
Careful with the sign. You have defined ##Q_1## as the amount of energy given by the condensed steam to the final mixture.
50
I still don´t get it. Did you mean the negative sign? I tried using + 65, but the answer still turns out wrong (m = .00695). The answer is supposed to be 22,7 g.
DrClaude
Mentor
6,372
2,625
Solving 2260m + 4,19m*65 = 333*0,120 + 4,19*0,120*35 for m, you should indeed get m=0.0227 kg.
50
I must´ve pressed something wrong on my calculator. Was a bit hasty...as usual. Now I got the right answer though. Thanks!
BvU
11,557
2,494
Fr0m the 28.9 g (the 0.0289 was kg) it follows you forgot the 4,19*m*65. Elementary, my dear Watson.
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
