Water velocity
  1. Jun 18, 2006 #1
    with static pressure(water in a tube or column) not moving. Is there an equation I can use to determine the velocity of the water by the pressure of the water in the tube or column.
  3. Jun 18, 2006 #2
    Astronuc
    Staff Emeritus
    In the first part, you write "static pressure(water in a tube or column) not moving." Then you ask about determining velocity. This is confusing.
    There is a pressure head, based on the elevation of the water. There is pressure based on the energy within the water, if the water is confined in a pipe, and there is the differential pressure applied to make the water flow in opposition to friction forces.
    Bernoulli's equation would be appropriate. But one has to know more than just static pressure.
    One can find useful information here -
    http://www.engineersedge.com/fluid_flow/fluid_flow_table_content.htm
    Also - Poiseuille's Law -
    http://hyperphysics.phy-astr.gsu.edu/hbase/poicon.html
    More on Bernoulli's Equation
    http://hyperphysics.phy-astr.gsu.edu/hbase/pber.html#beq
    http://hyperphysics.phy-astr.gsu.edu/hbase/bercon.html
    and
    http://wright.nasa.gov/airplane/bern.html
  4. Jun 18, 2006 #3
    Sorry I didn't explain properly. What I meant was water in a tube that is vertical. The water flows by gravity into another tube. I know how to calculate the pressure of the fluid, But I do not know how to calculate the flow rate of the water using the pressure value of the water in the tube.
