Water waves problem
  • Thread starter songoku
63
The figure shows water waves traveling between two points P and Q, 20.0 cm apart. A dust particle on the water surface makes 5 complete oscillations in 2.0 s.
What is :
i. The amplitude;
ii. The wavelength;
iii. The frequency;
iv. The speed of the waves ?
[tex]v=\lambda f[/tex]
i. amplitude = 4 cm
ii. I don't understand the question. The question states that "A dust particle on the water surface makes 5 complete oscillations" and I think there should be 5 waves, but in the picture there are only 2.5 waves.
The answer on the book is 8 cm. I guess it's from [tex]\lambda=\frac{20}{2.5}[/tex]
But the answer for frequency is 2.5 Hz. I guess it's from [tex]f=\frac{5\;\text{waves}}{2\;s}[/tex]
So I confused whether there are 2.5 waves or 5 waves.
Thanks
Answers and Replies
the information "5 oscillations per 2 seconds" is not linked to the picture
therefore the 8cm is correct, there are only 2.5 waves
you wrote down the formula you need;
v= lambda f
therefore using the information as you quite rightly said the frequencey is 2.5 Hz, frequency is after all number of oscillations per second
now you have the wavelength & frequency, the speed should be easy to work out
63
Hi Chewy0087
Ah I get it now. The information "5 oscillations per 2 seconds" is not about the picture but it's still related to the question because we can't determine the frequency just based on the picture.
Thanks
Related Threads on Water waves problem
  • Last Post
  • Last Post
