nagendranp
hi every one. its nice being with you. I'm a electronics graduate. & have a few doubts. i would be glad if explained.
thank you
thank you
nagendranp said:hi every one. its nice being with you. I'm a electronics graduate. & have a few doubts. i would be glad if explained.
thank you
berkeman said:schoolwork-type questions
nagendranp said:sir I am a business man I am having isues with a CCTV Camera & NVR. that's why I am here for homework there are plenty of prople locally here. if you know a solution please suggest or will make my own arrangements. thank you
There are a few potential reasons why a CCTV camera may not be recording. First, check the camera's power source and make sure it is properly connected. Next, check the camera's storage device (usually an NVR) and make sure it has enough space to record. If both of these are functioning properly, try resetting the camera or checking its settings to ensure it is set to record.
A black screen on a CCTV camera can be caused by a few different factors. First, check the camera's power source and make sure it is properly connected. Next, check the camera's lens and make sure it is clean and not obstructed. If these do not solve the issue, there may be a problem with the camera's image sensor and it may need to be replaced.
If your CCTV camera is displaying a distorted image, it could be due to a few different reasons. First, check the camera's lens and make sure it is clean and not obstructed. Next, check the camera's settings and make sure they are properly configured. If these do not solve the issue, there may be a problem with the camera's image sensor and it may need to be replaced.
If your NVR is not connecting to your CCTV cameras, there are a few potential solutions. First, check the network connection between the NVR and the cameras. Make sure they are properly connected and that there are no network issues. Next, check the NVR's settings and make sure they are properly configured. If these do not solve the issue, there may be a problem with the NVR itself and it may need to be replaced.
If your CCTV camera is not displaying live footage, there could be a few different reasons. First, check the camera's power source and make sure it is properly connected. Next, check the camera's settings and make sure they are properly configured. If these do not solve the issue, there may be a problem with the camera's image sensor and it may need to be replaced.
