Exploring Position Derivatives of Wave Function Initial Conditions
In summary, when finding the initial conditions of the velocity of a wave function, the derivative is taken with respect to position (x) instead of time (t). This is because the variables x and t appear as a sum or difference in the functions, making the derivatives equivalent up to a constant. The notation is written as a prime for convenience, and the derivative at t=0 represents the rate of change of the amplitude of the wave profile at a given position x.
pivoxa15
2,255
When doing the initial conditions of the velocity of the wave function, why do they have a position (x) derivative (i.e. cF'(x)-cG'(x)=h(x)).
It appears in here.
http://en.wikipedia.org/wiki/D'Alembert's_formula
How someone explain how the c came about and why position derivatives are taken instead of time derivatives?
Well in the article it just uses the prime notation to represent a derivative, and not [itex]\partial/\partial x[/itex] or [itex]\partial/ \partial t[/itex].
The first thing to note is that [itex]u(x,t)=F(x-ct)+G(x-ct)[/itex], so if you take a time derivative of one of these functions, you will pull out the constant [itex]c[/itex] because
[tex]
\frac{\partial}{\partial t} \equiv c\frac{\partial}{\partial(ct)}.
[/tex]
The second thing to note is that because the variables [itex]x,t[/itex] in the functions [itex]F\,, G[/itex] appear as a sum or difference, then differentiating with respect to [itex]t[/itex] will give the same functional form as a derivative with respect [itex]x[/itex], up to some constant. For example,
[tex]
f(x-ct) = \sin(x-ct)
[/tex]
Then
[tex]
\frac{\partial}{\partial x}f(x-ct) = \cos(x-ct) = \frac{\partial}{\partial(-ct)}\sin(x-ct) = \frac{-1}{c}\frac{\partial}{\partial t}\sin(x-ct) = \frac{-1}{c}\frac{\partial}{\partial t}f(x-ct)
[/tex]
The reason why they write the derivative in this primed notation is because the conditions require that the time derivative is evaluated at [itex]t=0[/itex], which you could write like this:
[tex]
\left.\frac{\partial}{\partial t}f(x,t)\right|_{t=0} = h(x).
[/tex]
The notation is pretty cumbersome so instead they just write:
[tex]
f^{\prime}(x,0) = ch(x).
[/tex]
I think this is right, but maybe someone else could clarify?
Your explanation seems to make sense. It might also got something to do with the (trademark) equality of the second derivative that defines a wave equation. But physically, if you denote the time derivative of the wave with constant speed with c*(spatial derivative), than it means at different locations, it will have different velocities, not just in direction but also in magntitude.
If you treat the partial time derivative in terms of the x variable than you could integrate it wrt x and get the original wave function back instead of integrating wrt t.
Of course there is an equivalence between the derivatives (up to some constant) because of how the argument of the function is written. This is precisely what I was trying to tell you in my first post.
I'm not sure what you're saying here about the wave having different velocities?! The velocity is a constant, c, (independent of coordinates).
By the way in my first post G(x-ct) should be G(x+ct).
What is the physical interpretation of
[tex]
[/tex]
if it is not the wave's velocity?
The interpration of this is
"The rate of change of the amplitude of the wave profile for some given [itex]x[/itex] at [itex]t=0[/itex]".
For example, plot out some wave profile as a function of [itex]x[/itex]. Go to some coordinate [itex]x^{\prime}[/itex] along [itex]x[/itex]. Draw a line from [itex]x^{\prime}[/itex] to [itex]u(x^{\prime})[/itex]. Your initial condition is telling you how much larger or smaller this line will become in some small time interval [itex]\Delta t[/itex]. This is not the velocity of the wave. The velocity of the wave is how far the wave profile propogates along [itex]x[/itex] for some given amount of time [itex]t[/itex].
1. What is the purpose of exploring position derivatives of wave function initial conditions?
The purpose of exploring position derivatives of wave function initial conditions is to gain a better understanding of how the wave function changes over time. This can provide insights into the behavior of quantum systems and help in predicting their future states.
2. How are the position derivatives of wave function initial conditions calculated?
The position derivatives of wave function initial conditions are typically calculated using mathematical equations, such as the Schrödinger equation. These equations take into account various factors, such as the potential energy of the system, to determine the rate of change of the wave function with respect to position.
3. What are some potential applications of exploring position derivatives of wave function initial conditions?
Studying the position derivatives of wave function initial conditions can have various applications, such as in quantum computing, quantum cryptography, and quantum sensing. It can also help in understanding the behavior of particles in quantum systems, which can have implications in fields such as chemistry and material science.
4. What are some challenges in exploring position derivatives of wave function initial conditions?
One of the main challenges in exploring position derivatives of wave function initial conditions is the complexity of the mathematical equations involved. These equations can be difficult to solve, and even small errors in calculations can significantly impact the results. Additionally, experimental techniques for measuring position derivatives can also be challenging and require advanced technology.
5. How does exploring position derivatives of wave function initial conditions relate to the uncertainty principle?
The uncertainty principle states that it is impossible to know both the position and momentum of a particle with absolute certainty. By exploring position derivatives of wave function initial conditions, scientists are essentially trying to determine the position and momentum of a particle at a specific time, which is limited by the uncertainty principle. This relationship is an important aspect of understanding the behavior of quantum systems.
