Solving U_{tt}=9U_{xx} with Laplace Transforms
In summary: Therefore, the solution is:In summary, we can solve the given equation using Laplace transforms to find the solution U(x,t) = \frac{s}{s^2+9} \sin x, with the initial conditions U(x,0)=sinx and U_t(x,0)=0.
pk415
We are supposed to work this using Laplace transforms
[tex]U_{tt}=9U_{xx}; -infty<x<infty[/tex]
[tex]U(x,0)=sinx[/tex]
[tex]U_t(x,0)=0[/tex]
The attempt at a solution
[tex]Let L=\hat{U}[/tex]
[tex]L[U_{tt}]=s^2\hat{U}-s(sinx)[/tex]
[tex]L[9U_{xx}]=9\hat{U}_{xx}[/tex]
[tex]s^2\hat{U}-s(sinx)=9\hat{U}_{xx}[/tex]
[tex]\hat{U}_{xx}-\frac{s^2}{9}\hat{U}=-\frac{s}{9}sinx[/tex]
This is a second order nonhomogeneous equation where the homogeneous solution is
[tex]\hat{U}_h=A(s)e^{\frac{s}{3}x}+B(s)e^{-\frac{s}{3}x}[/tex]
and the particular solution is
[tex]\hat{U}_p=\frac{s}{s^2+9}sinx[/tex]
Then we have
[tex]\hat{U}=A(s)e^{\frac{s}{3}x}+B(s)e^{-\frac{s}{3}x}+\frac{s}{s^2+9}sinx[/tex]
We know that
[tex]\lim_{x\rightarrow\infty}U=0[/tex]
[tex]\lim_{x\rightarrow{-\infty}}U=0[/tex]
That second one should say limit as x approaches negative infinity, can't figure out how to get latex to do that
[tex]\lim_{x\rightarrow\infty}\hat{U}=0[/tex]
Second one negative infinity again
If we plug these in we get
[tex]A(s)=\frac{\lim_{x\rightarrow\infty}\frac{s}{s^2+9}sinx}{\lim_{x\rightarrow\infty}e^{-\frac{s}{3}x}}}[/tex]
[tex]A(s)=0[/tex]
I'm not sure if that last step is legal, but if it is you can use the same reasoning for B(s)
Any ideas?
Your solution is on the right track, but there are a few errors and missing steps. Here is a more detailed explanation of the solution:
First, let's take the Laplace transform of the given equation:
L[U_{tt}] = s^2 \hat{U} - sU(x,0) - U_t(x,0) = s^2 \hat{U} - s\sin x
L[9U_{xx}] = 9\hat{U}_{xx}
Since we know that U(x,0)=sinx and U_t(x,0)=0, we can plug these values in and simplify:
s^2 \hat{U} - s\sin x = 9\hat{U}_{xx}
Next, we can use the initial conditions to find the values of A(s) and B(s) in the homogeneous solution. Plugging in the initial conditions, we get:
A(s) + B(s) = 0
\frac{s}{3}A(s) - \frac{s}{3}B(s) = 0
Solving these equations, we get A(s)=0 and B(s)=0.
Now, for the particular solution, we can use the method of undetermined coefficients. We assume a particular solution of the form:
\hat{U}_p = K(s) \sin x
Plugging this into the equation, we get:
K(s) = \frac{s}{s^2+9}
Therefore, the general solution is:
\hat{U} = A(s)e^{\frac{s}{3}x} + B(s)e^{-\frac{s}{3}x} + \frac{s}{s^2+9}\sin x
Using the initial conditions to solve for A(s) and B(s), we get A(s)=0 and B(s)=0.
Finally, taking the inverse Laplace transform, we get the solution:
Note that the limits as x approaches positive and negative infinity are both 0, as expected.
1. What is the Laplace Transform?
The Laplace Transform is a mathematical tool used to solve differential equations by transforming them from the time domain to the frequency domain. It is denoted by the symbol "L" and is commonly used in engineering and physics applications.
2. What is the significance of U_{tt}=9U_{xx}?
This equation represents a second-order partial differential equation, where U is a function of both time (t) and space (x). It is commonly known as the wave equation and is used to model various physical phenomena such as vibrations, sound waves, and heat conduction.
3. How does the Laplace Transform help in solving U_{tt}=9U_{xx}?
The Laplace Transform converts the differential equation into an algebraic equation in the frequency domain, making it easier to solve. This is because the transform has the property of turning derivatives into simple algebraic expressions.
4. What are the steps involved in using Laplace Transforms to solve U_{tt}=9U_{xx}?
The steps involved include applying the Laplace Transform to both sides of the equation, using algebraic properties to simplify the transformed equation, and then applying the inverse Laplace Transform to obtain the solution in the time domain.
5. Are there any limitations to using Laplace Transforms for solving U_{tt}=9U_{xx}?
Yes, Laplace Transforms can only be applied to linear differential equations with constant coefficients. They also require initial conditions to be known, and the solution may not be valid for all values of t and x.
