Wave equations of spin 1,2,3,4
  • Thread starter eljose79
  • Tags
    Spin Wave
In summary, the conversation discusses the construction of wave equations for arbitrary integer and semi-integer spins, specifically in relation to the spins of isotopes and the intrinsic spin of the electron. It suggests writing down a wave equation for a specific spin or using combinations of lower spin wavefunctions to calculate the wave equation.
eljose79
1,518
Wave equations of spin 1,2,3,4...
HOw could you construct wave equations of arbitrary integer (or semi-integer 1/2,3/2...) spin?...
Hi E,
If you observe the spins of the isotopes (see standard table of the isotopes of the atoms), you will see that most [some have zero spin] are either even or odd numbered combinations of 1/2, which is the intrinsic spin of the electron. Cheers, Jim
You could just write one down, eg |3/2>. Or you could write that as a combination of lower spin wavefunctions -- see addition of angular momentum and Clebsh-Gordon coefficients.
1. What is a wave equation of spin 1?
A wave equation of spin 1 is a mathematical equation that describes the behavior of a particle with spin 1 in quantum mechanics. It is used to determine the probability of finding the particle in a certain location and its properties, such as energy and momentum.
2. How is the wave equation of spin 2 different from that of spin 1?
The wave equation of spin 2 is more complex than that of spin 1, as it involves tensors and higher-order derivatives. This is because spin 2 particles, such as gravitons, have more degrees of freedom and require a more comprehensive equation to describe their behavior.
3. Can the wave equation of spin 3 be applied to all particles with spin 3?
No, the wave equation of spin 3 is specific to particles with spin 3 in the context of quantum mechanics. Other systems, such as classical mechanics or electromagnetism, may have different equations to describe particles with spin 3.
4. How are the wave equations of spin 1, 2, 3, and 4 related?
The wave equations of spin 1, 2, 3, and 4 are all based on the same principles of quantum mechanics, but they differ in complexity and the specific properties they describe. Each equation builds upon the previous one, with the wave equation of spin 4 being the most comprehensive and complex of the four.
5. Can the wave equations of spin 1, 2, 3, and 4 be solved analytically?
It depends on the specific equation and the system it is applied to. In some cases, the equations can be solved analytically, but in others, numerical methods may be necessary. Additionally, the solutions may be approximate rather than exact due to the complexity of the equations.
  • Other Physics Topics
  • Quantum Physics
  • Astronomy and Astrophysics
  • Atomic and Condensed Matter
