What is a Wave Function? Exploring k and $\omega$
In summary, we discussed a function of the form $u(x,t)=A \cos{(kx-\omega t)}$, where $k>0, \omega>0, A>0$, which is called a wave function. We also learned that if this function is a solution of a differential equation with partial derivatives, it is referred to as a solution in the form of a wave function. The parameter $k$ is known as the wavenumber and $\omega$ is called the circular frequency. Additionally, we discovered that $\frac{2\pi}{k}$ represents the wave length and is similar to the period $T$, for which we have $\omega=\frac{2\pi}{T}$. The velocity of
evinda
MHB
3,836
Hello! (Wave)
A function of the form
$$u(x,t)=A \cos{(kx-\omega t)}, \text{ where } k>0, \omega>0, A>0$$
is called wave function. If in addition $u(x,t)$ is the solution of a differential equation with partial derivatives we are talking about a solution of the differential equation in the form of a wave function.
$k$ is called wavenumber and $\omega$ is called circular frequency.
$k$ counts the cycles that the wavefunction makes at the space interval of length $2 \pi$-in respect to $x$.View attachment 4140What does $\frac{2 \pi}{k}$ represent? What does it count? :confused:
Hey! (Wink)
$\frac{2 \pi}{k}$ is the wave length, usually represented by the symbol $\lambda$. (Wasntme)
It is similar to the period $T$ of a wave, for which we have $\omega = \frac{2\pi}{T}$.
You may also run into the frequency $f$ of the wave, which is $f = \frac{1}{T}$.
The velocity $v$ (or sometimes $c$) of a wave is its wave length $\lambda$ divided by its period $T$. (Nerd)
I like Serena said:
Hey! (Wink)
Then there is the following definition:
$\omega$ counts the cycles that the wave function makes in the time interval $2 \pi$- in respect to $t$.
So $\frac{2 \pi}{\omega}$ is equal to the period, right?
Can we see it at the above graph? Or would we have to draw an other one? (Thinking)
Yep. That's the period.
And we would need another graph. (Wasntme)
The graph you have is of $u(x,t)$ versus $x$, where $t$ has some fixed value.
You're talking about a graph of $u(x,t)$ versus $t$, with a fixed $x$ value. (Thinking)
Ah, I see... So it will be exactly the same graph with the only difference that the perpendicular axis will represent $t$ instead of $x$. Right? (Thinking)
Yep. (Nod)
I like Serena said:
Yep. (Nod)
Great! Thanks a lot! (Angel)
1. What is a wave function?
A wave function is a mathematical description of a quantum system, which represents the probability of finding a particle in a certain state or position at a given time. It is a complex-valued function that evolves over time according to the Schrodinger equation.
2. How is the wave function related to k and $\omega$?
In quantum mechanics, the wave function is often represented by the symbol $\psi$. This function contains both the spatial wave function, which is related to the spatial coordinate k, and the temporal wave function, which is related to the frequency $\omega$. Together, they describe the behavior of a particle as a wave and determine its energy and momentum.
3. What is the significance of k and $\omega$ in the wave function?
K and $\omega$ are important parameters in the wave function as they determine the properties of a particle, such as its position, energy, and momentum. The values of k and $\omega$ also determine the shape and behavior of the wave function, which can provide information about the probability of finding the particle at a particular location or time.
4. How does the wave function change over time?
The wave function evolves over time according to the Schrodinger equation, which describes the time evolution of quantum systems. As time progresses, the wave function changes in both its spatial and temporal components, reflecting the changing position and energy of the particle.
5. Can the wave function be observed or measured?
No, the wave function itself cannot be directly observed or measured. However, the wave function can be used to calculate the probabilities of different outcomes for a particle, which can then be measured through experiments. The wave function is a theoretical construct used to describe the behavior of particles in quantum mechanics.
  • Differential Equations
