Wave guids
  1. Aug 29, 2011 #1
    Hi,
    For experts among you it might be trivial, but I am not exactly "at home" here :confused:
    so, here it goes:
    1.Does the "cut off frequency" in waveguides apply to all incident angles of electromagnetic waves propagation through the waveguide or not.
    2. Does the shape of cross-section (circular or rectangular) plays any role in this?
    3.Does this apply also to waves propagating parallel to the walls (or main axis) of waveguides (usually this is direction "z"): so no waves reflecting from walls due to incident angle.
    4.Is "cutoff" 100% or do some electromagnetic waves "leak out" at that frequency (or lower)
    at the open end.
    5.Has length anything to do with it: how long must the ratio (length/width) be, for those "rules" to be valid. Is there such thing, as minimum
    Many thanks,
    Rok
  3. Aug 29, 2011 #2
    I'm not an expert either, but we're all here to learn.
    1. Certainly there will be a loss when you insert a wave with oblique incidence into a waveguide, but if you just consider a wave already propagating inside a rectangular or circular waveguide, the wave will propagate in set modes dependent on the source frequency and dimensions of the waveguide.
    2. The shape will change the solution of the wave equation by changing the boundary conditions, and thus change the cutoff frequencies.
    3. This shouldn't matter, if I understand the question.
    4. Cutoff is due to the propagation constant becoming imaginary below a certain cutoff wavenumber (or frequency), therefore the wave will exponentially decay with no propagation component. Theoretically this is 100%, but in reality we might see -50 dB of power transmission.
    If you have an open end of the waveguide with no termination into a load, you will have an impedance mismatch with some reflection.
    5. The major (a) and minor (b) dimension of the waveguide determines the cutoff frequencies of each mode. I suppose there is no such thing as a minimum waveguide size, as smaller ones are intended for higher and higher frequencies and you will find that the cutoff frequencies rise to optical levels if you get ridiculously small - not good for RF work.
    Electromagnetics isn't an easy subject, so I recommend you start at the beginning. I like the Microwave Engineering book by Pozar.
  4. Aug 29, 2011 #3
    Thanks, PatrickEE...
    Yes, Electromagnetics isn't an easy subject, but interesting one. Unfortunately, I don't have time to dig dipper into it. There are some good lectures on internet, though: http://ocw.mit.edu/courses/physics/...nd-waves-fall-2004/video-lectures/lecture-17/
    So, let's say, I want to have some kind of selective frequency waveguide, something like one you can see in attachment. So the question is, if I have a standing wave on the opening, do the blue lines get reflected as well as red ones? Presuming a is approx. 1/2 wavelength. So the question is, does the cutoff frequency apply also for blue, as well as red ones. I think, it does, although, it seem a bit counter intuitive to me (-50dB seems quite close to perfect to me)..
    I want higher frequencies to be able to pass....
Loading...
