Exploring the Nature of Light: Is Light Made of Particles or Waves?
In summary: There is no problem of either. "Wave-particle duality" is a loose term from early days when quantum phenomena were first being seen to describe that the phenomena resembled how classical particles and classical waves behaved. In those days, quantum theory was only known as incoherent pieces of the puzzle. Nowadays, we do have a quantum theory in which the pieces are coherently assembled. Some people don't like the term "wave-particle" duality because it comes from a time when people did not fully understand quantum theory. Others, like me, think the term is fine, since the early apparently disparate pieces have now been properly synthesized. Regardless, we should all just agree to call it "
KiNGGeexD
317
I have been reading Richard Feynmans Quantum Electrodyamics and quite early in the first chapter he asserts that Photons are particles. His reasoning that as you decrease the intensity of light incident on a photomultiplier the clicks which the multiplier make become less frequent but equally loud. He doesn't go into much more depth on this issue and assumes particles in there "corpuscular" interpretation. However I always imagined light as quanta. Packets of photons, so is it not the case that decreasing intensity just decreases the number of quanta?
Feynman states there are properties which support his assertion and I was hoping Physics Forums could shed some light on them, excuse the pun
Wave particle duality is an outdated concept, in qft everything is fields. Once you quantize those fields, there are some states with definite momentum which can be interpereted as particles.
People should really stop teaching wave particle duality.
Likes Steve Lajoie, Ilja and Ponderer
I'm just going into my honours year so wave-particle duality was a concert introduced! Any helpful resources?
I am trying to understand the exact problem of particle wave duality. Perhaps somebody can correct me but it seems to me an electron is a negatively charged particle, i don't think most people would disagree. However, it has wave associations only when a voltage is applied to create a flow of electrons. Only then has it an electro magnetic field surrounding it in concentric circles, which rotate around an electric cable or beam of electrons in a direction as described by Maxwell's corkscrew rule. If the carrier frequency of electrons is modulated as in Radio, the radiating electric field causes the associated electromagnetic field, which is at right angles to the electric field, to reflect the electric field wave pattern. This electromagnetic field travels infinite distances the same as gravity and these waves react easily with other electromagnetic or magnetic influences.
Recapping: an electron has no wave properties until a voltage is applied, but then it has.
Google for "electron double slit".
If I had a dollar for every time someone outside of PF preached this as dogmatically, I would have zero dollars.
Likes jerromyjon, e.bar.goum and micromass
You will find the concept coherently formalized when you study quantum theory properly. The quantum particle is a fundamental concept in quantum mechanics. Unlike a classical particle, a quantum particle does not have simultaneously well-defined position and momentum. However, it is like a classical particle in that it can be counted using the integers. However, there is a wave equation that governs the probabilities of experiments performed on the particle(s).
Yea I assumed anything quantum would obey the Uncertainty principle, it all seems rather vague at times. I suppose no one really knows
I must admit I know nothing of quantum theory, but I do know how Televisions And Radios are designed and work. On tried and trusted physics formulas from people like: Faraday, Ohm, Watt, Maxwell, Lenz, and many more. I will however study more about quantum mechanic before I criticize it.
No one really knows what? That quantum objects are just that and not classical particles or waves?
Good luck King... If you are just being introduced to these ideas, and aren't going to be using them professionally, I have a piece of advice (as a non-physicist)... Learn the formulas, run the numbers and call it a day. OR, prepare to have your world view significantly altered for the rest of your life.
There is no problem of "particle-wave duality". There is only a problem of "wave-particle duality". Kidding!
There is no problem of either. "Wave-particle duality" is a loose term from early days when quantum phenomena were first being seen to describe that the phenomena resembled how classical particles and classical waves behaved. In those days, quantum theory was only known as incoherent pieces of the puzzle. Nowadays, we do have a quantum theory in which the pieces are coherently assembled. Some people don't like the term "wave-particle" duality because it comes from a time when people did not fully understand quantum theory. Others, like me, think the term is fine, since the early apparently disparate pieces have now been properly synthesized. Regardless, we all agree that we now have a quantum theory that makes complete sense.
So there are no classical particles. There are only quantum particles, which differ from classical particles in that they do not have simultaneously well-defined positions and momenta. There are also no classical waves. Quantum particles are described by equations that have wave-like properties and particle-like properties, and yet are different from classical particles and classical waves.
No one really know what electrons are, they have never been observed, along with a lot of constituent parts of matter (strings) it was a general comment which I regret ;)
Likes Lord Crc
As far as quantum objects I suppose it's hard to say what they really are except from mathematical abstractions
That is all fine, I'm aware I have only scratched the surface of the quantum world. However we do not have particle equations? We have wave equations? Or is this a matter of mere naming
I don't know what a "particle equation" would be in this case. The wave equation gives the probability of finding the a particle if you measure for a particle.
Come now, I count at least two dollars.
But as far as the properties of said particle which we have a probability for?
It is mostly a matter of naming. One could say we have wave equations for particles. It is best to learn the formalism properly, and just get used to the fact that different people use different naming conventions.
Because if we call it a particle we collapse the wave function to a single point? So it cannot have a probability to be "everywhere" like quantum theory boasts
When you measure the position of a particle it collapses to a single point. Prior to said measurement (the standard interpretation of QM states that) the particle exists in a "spread out" state over an area.
First - I'm just a guy (geophysics undergrad - many years ago), so I'm just giving my ideas - not necessarily correct or complete.
I'm struggling with this as well.- along with fields. Here's what I see so far. Feyman says a photon is a particle in QED - forget waves. Sean Carroll says forget particles and focus on fields instead. A particle is just the result of a collapse of the uncertainty of position and momentum. But he's really speaking of probability fields - with the probability defined but QED theory (probability amplitudes based on time oscillations). If we think of each location in space of a photon at a particular time, it has a certain probability to be in another location in space at another time - each of these other locations has a probability of being there depending on the distance. If you think about it, areas of equal distance from the starting point creates a sphere. So the probability fields are infinite numbers of spheres, representing the same distance from the starting point. What seems to matter is time not distance, but since the photon is traveling at constant speed (c), if the medium traveling through is uniform, then location in space means the same amount of time has elapsed. Each of these probability spheres is really what a field is defined as. An aside - recognizing it as fields helps conceptually and mathmatically, but I don't think it necessary helps with the concept that Newton struggled with - action at a distance.
But there's also another wave concept besides wave-particular duality - probability waves - that makes no sense to me if my definition of a wave is correct - interaction with adjacent particles/positions.
Here's what I mean. What's the difference between a wave and a field? I think the answer is that a wave interacts with its neighbors. Like dominoes or water. That's the thing that Sean Carroll and others leave out in layman talks they give. Waves "propagating" through the field. Amber waves of grain move in the same direction from a force (the wind) but they do not push on each other - well maybe a little but it's primarily the wind. Feyman says photons and electrons are not acting as a wave to explain QED. He says it's been tested - I believe him but if so that means that each photon is not interacting with it's neighbor. Predicting whether a photon from one source location will arrive in another location is independent of other photons. Each photon carries an internal mechanism - a probability mechanism that oscillates from zero to a max probability - who knows how this works. It's independent so it can't be a wave. It's a disturbance in space-time field that can be thought of as a particle. And it becomes that particle only when we bother to measure it; otherwise it is just a probable disturbance in a particular location in the space-time field - with the probability changing in spheres of equal probability throughout the universe.
What's the conclusion of my rambling? Modern physics says that waves are out. Even the concept of probability waves is misleading. Unless and until we discover some interaction between particles. But I think physics still think of light "propagating" through space, when QED says it's more about probabilities. I don't think you can think propagating without waves - so the real duality is you use whichever concept works best as an approximation given the problem you're trying to solve, but the best understanding of the universe is not-wavelike, but a weird probability situation. There are instances where you can use probability computation to solve the problem but other times wave works as well and might be easier mathmatically.
To all of you that know more than I do (a huge number) - please remember to use terms like "misled" "lacks complete understanding", etc., as opposed to "moron" "feather brain" etc. Partly I'm writing this to get it clear in my own head - and things are very fuzzy there most of the time.
Lews
Lews
I'm comfortable with all of that. I know about wave equations and particles however I just wasn't sure about Feynman's logic
Or rather his assertion that photons are particle-like
No, a quantum particle is "everywhere" or "potentially anywhere". If we measure its position we collapse the wave function to a single point.
Another way to see the wavelike nature of a quantum particle is to use Feynman's picture that a quantum particle takes all possible paths, whereas a classical particle takes only one path. The effects of quantum mechanics require Planck's constant for their description. When we make Planck's constant smaller and smaller in the quantum formalism, the quantum formalism becomes closer and closer to the classical formalism in which the particle takes only one path.
Of course that is clear thank you
In my opinion, "wave/particle duality" has a conceptually revealing element, and a conceptually obscuring element, so the key is to stress only the part that is useful and eliminate the other. The useful part is that when we thought classically, we used to think that particles and waves were two completely different things, with a firewall between them. When a homerun is hit in baseball, you had a particle flying out of the stadium, and a rush of sound waves following it as the fans cheered, and no connection whatsoever existed between those. So it is very enlightening to understand that actually everything that baseball is doing could be expressed in the mathematics of a well-localized wave with very short wavelengths, and everything that rush of sound was doing could be expressed in the mathematics of particles moving stochastically, and in turn the movement of those particles could be expressed as localized waves with very short wavelengths. So perhaps "wave/particle unity" would be a better phrase-- it just means that everything that we thought was a particle also involves the rules of waves, and everything we thought was a wave also involves the rules of particles. But I don't throw away wave/particle duality, I just think wave/particle unity every time I hear the phrase.
Which brings up the obscuring aspect of the phrase, which I believe is the part most of its detractors object to. They object, and rightly so, to the interpretation that "wave/particle duality" means "sometimes it's a particle, and sometimes it's a wave, depending on the question we put to it." That makes it sound disjoint and schizophrenic, when in fact it's the opposite of that, it's well unified into an elegant and aesthetically beautiful theory, just one that is not like we used to think when we thought waves and particles were two completely different things. So the problem is not with the "duality", it is with the whole idea that there are two separate things there that would need to be "dual" to be thought of as elements of the same thing. Shall we say that a coin exhibits "head/tail duality", or shall we just say there are "two sides to the same coin"?
Likes Simon Clement and atyy
That's probably the best answer I have had so far on the matter.Regards
Wave equations are not particles and it is unfortunate that they are even called 'wave equations'. They are probability distributions. This probability distribution is not a particle. It is a mathematical construct, a probability distribution. If you have a probability distribution for IQ for the human population, that distribution is not the population, so why do you think the probability distribution for a particle is the particle itself?
A particle is a positive result in a particle detector.
A wave equation is the probability of finding the position or momentum or some function using the particle detector.
Landau and Liftshitz nailed this way back in the middle 20th century. Yes, I was taught the "wave particle duality" misconception as well. Then I went to a better university.
And yet, you have just described what "wave/particle duality" actually is! It is the statement that particles are what register in particle detectors, and waves are what exhibit magnitude and phase so can interfere, and many particle accelerator experiments are going to use both of those concepts to interpret their results. Maybe the worse university gave you the wrong way to think about "wave/particle duality", and there are better ways to frame that duality, but the duality is still right there in what you just said. I think the real problem is associating "duality" with "multiple personality disorder," though the two are not necessarily synonymous. Look at other dualities in physics, like the Maldacena duality-- no one says a conformal field theory sometimes acts instead like an anti-de Sitter space, they just say the two are opposite sides of the same coin under scale inversion.
Likes e.bar.goum
  • #31
I agree a wave and particle cannot be separated, but the wave function of electromagnetic radiation carried by photons is only present when we have a flow of electrons.
  • #32
I have only thought about wave particle duality recently, have to look up Maldacena duality. get back to you soon.
  • #33
Indeed. Detractors of the concept of wave-particle duality like to show they are more "high class" than standard textbooks. But the duality is deep in the subject, so much so that "quantum field theory" is the language of "particle physics"!
[I concede that at the most rigourous level, probably the fields are more fundamental. However, the informal presentation in books like Weinberg's or Nair's approach quantum field theory from the viewpoint of particles. Also, a lot of string theory is formulated in first quantized language.]
  • #34
There is no wave. The graph of the probability distribution looks like a wave, and follows the similar math as a wave (but with phase differences that require in the most general case complex and not real solutions), but there is no medium to this wave, it is a mathematical description of the probability of getting a "ping!" in a particle detector.
Would you call it a "Probability distribution/particle duality"? Nope.
Best to not even call it a wave, as it causes confusion.It is not a wave; waves are physical phenomena. Oceans waves and sound waves. It confuses beginning QM students. In QM, the Schrodinger equation's solutions are probability distributions, not "waves".
I'm pretty sure that Landau and Lifshitz is a standard textbook.
  • #35
Do L&L dislike the term?
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
