Wave / Phase Problem, Need help!
  1. Jan 26, 2006 #1
    Hi, I have two question.....I spent 2 hrs on these two but couldnt fins out how to solve it...can any one show me right way? hint?
    A sinosodial wave of frequency 500Hz has a speed of 350 m/s
    a. How far apart are two points that differ in phase by Pi/3 rad?
    b. What is the phase difference between two displacments at a certain point at times 1.00ms apart?
    the function y(x,t)= (15.0 cm) cos ((pi)x-15(pi)t) with x in meters and t in secconds, describes a wave on a taut string. what is the trasnverse speed for a point on the string at an instant when that point has the displacement y= +12.0 cm?
  3. Jan 26, 2006 #2
    Staff: Mentor
    1) Use units to help you work with this. Remember that Hz = 1/seconds. So what is the wavelength in meters for a 500Hz wave travelling at 350m/s? Carry the units along in your calculation the same way as you do the numbers...units in the numerator multiply together, and units in the denominator multiply together. Like, a 10Hz wave travelling at 5m/s has a wavelength of (5m/s)/(10/s) = 0.5m. See how to do that? Once you figure out what the wavelength is for the problem, that is 2*PI of its phase....
    2) Do you know what is meant by transverse speed? It is motion of the string in which dimension? And speed is just the derivative of the position with respect to time....
  4. Jan 27, 2006 #3
    Hi thanks for your reply. But none of your hints were helpful. I mean I already know these stuff...But I wanted to know what to do after that????
    How to relate the given values in the problem?
  5. Jan 27, 2006 #4
    Staff: Mentor
    Well if you know the wavelength, and a wavelength is 2*Pi radians, then how far apart would two points Pi/3 radians be apart. Seems pretty straightforward once you have the wavelength, eh?
    And if you have the wavelength and linear velocity, how much phase rolls by in 1ms?
    And on 2), if you understand what transverse speed is, what partial derivative of y(x,t) do you want to use to calculate that speed?
  6. Jan 27, 2006 #5
    hmm thanks... no. 1 question is making some sense..now...haha
    and thnks for making it clear
    and on no. 2 I tried taking devitaive before with respect to time.
    it gives
    dy/dt = 15.0 cm (-sin((pi)x-15(pi)t)) * ((pi)x-15(pi)))
    now where a I suppiosed to plug in that given y= +12.0 cm at?
  7. Jan 28, 2006 #6
    Anyone can give me more hint??
  8. Jan 29, 2006 #7
    No one? ?
Similar Threads - Wave Phase Problem Date
Phase shift of e.m. wave through a glass plate Apr 6, 2017
Simple wave problem - phase constant May 5, 2016
Produce Standing Wave Problem Apr 28, 2015
Wave Problem - Phase Shift Sep 6, 2013
Waves - phase problem. May 18, 2011
