1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Wave Questions
  1. Dec 1, 2005 #1
    Hey guys i've got a few questions I didn't know how to do and would appreciate if you could help me out...
    A wave generator is used to produce transverse waves in a string that is 12 metres long. Initially, the wave generator is set to a frequency of 5.0 HZ
    a) How many wavelengths are being created each minute by the wave generator? (Hint: how many in one second?)
    b) What is the period of the wave being gnerated?
    c) If the speed of a wave in the string is known to be 15 m/s, what is the length of one wave?
    d) The frequency of the wave generator is now changed so that it produces a standing wave pattern along the string. An observer counts 3 nodes along the entire length of the string. What is the frequency of the wave generator when it is producing this standing wave?
    I am aware that frequency and periods are inversly related
    T = Period
    f = frequency
    Therefore: T = 1/f & f=1/f
    equations we are given to use are:
    v= d/t & v=f(wavelength) (velocitiy equals frequency times wavelength.)
    Would love some help..
    Thanks in advance.
  3. Dec 1, 2005 #2
    Did you answer the hint question? If there are 60 seconds in 1 minute, how many seconds are in 1 hour? If there are X waves in 1 second, how many waves are there in 1 minute?
    Part b won't be a problem since you have your equations there.
    Part c as well ^^
    Part d is a standing wave situation. The generator must be generating at the wire's resonant frequency. You'll have to assume that the other end is a fixed end. It's easier to start from finding the resonant wavelength of the third harmonic, or do you remember the equations for this?
  4. Dec 1, 2005 #3
    in question a would the answer be?
    5 cycles/second = 60 s * 5 cycles/s = 300 cycles a minute
    Therefore in question a the wave machine would generate 300 wavelengths per minute
    b) T=1/f T=1/5hz T=0.2 seconds Therefore the period is 0.2 seconds
    c) I am not exactly sure which equation to use here v=d/t or v=f*(wavelength)
    d) I still am unsure of how to start this
  5. Dec 1, 2005 #4
    If your calculations are logical, be a bit more confident in your answers ^_^
    c. What two variables do you have? velocity, frequency, wavelength, distance, time. Pick the right one that would solve.
    d. I wouldn't want to give you an equation if you don't know what it means. You can read http://www.cord.edu/dept/physics/p128/lecture99_35.html#topic3 [Broken]
    You're looking at a case where one end is open (movable) and the other end is fixed.
  6. Dec 1, 2005 #5
    I think I'll leave d and go for help for that tomorrow
    its just c
    v= 15m/s
    d=? asked to find
    wavelength= 300?
    if I use v=d/t for question c) then d=t*v
    it doesn't work
    ..... v=f times wavelength then:
    wavelength = v/f
    wavelength = 3m? ^_^
  7. Dec 1, 2005 #6
    The equation d = vt should not be new to you. You use it every day in life. If you are driving at 100 miles/hr and going to a nearby city 200 miles away, how long will your journey be? Surely you can figure that out.
    The equation [tex]v = f \lambda [/tex] can be shown similarly. If you know the wavelength and frequency of the wave, you can find its velocity. Or if you know any 2 of the 3. From your last three lines, I think you have an answer ;)
  8. Dec 1, 2005 #7
    i know the v=d/t quite well...its just which to use with each variable...
    I understand c.
    I would like to thank you for the help once again.
    Keep the blue side up.
Similar Threads - Wave Questions Date
Waves questions from Cambridge physics paper 9702 Nov 11, 2017
Longitudinal Wave questions Mar 23, 2017
Question about Gaussian wave packet Mar 15, 2017
