Homework Help: Wave sine function
  1. Apr 2, 2016 #1
    A sine function is given.And the question is At which time does the deflection (y) reaches a maximum?
    y= 3sin (800πxt+π/3)
    2. Relevant equations
    y= A sin (wt+Φ)
    A=amplitude
    w= angular frequency
    Φ= initial phase
    3. The attempt at a solution
    I already have solution. But I don't understand it .
    800πt+π/3 =π/2 +kx2xπ
    800πt=π/6 + k x2xπ
    t=1/4800 + k x 1/400
    What does that k stands for ? and why is it kx2xπ and π/2 why not π/6
  3. Apr 2, 2016 #2
    PeroK
    When is the sine function at a maximum? If you have ##y = 3sin(x)## for what value(s) of ##x## is ##y## a maximum?
  4. Apr 2, 2016 #3
    3 ???
  5. Apr 2, 2016 #4
    PeroK
    3 is the maximum value of that function, but for which values of ##x## does it have that value?
  6. Apr 2, 2016 #5
    your y is function of t and you are writing condition for it -
    you know that a sine function oscillates between zero and 1 - so you are putting the condition as first maxima will be at pi/2, but for a wave there will be second, third maxima of y....and so on ,that is written as additional term where k=0,1,2,..... can be substituted and again one can get maxima- as after 2.pi addition one again reaches the max. y value... one can draw a diagram of y- phase curve and see how it repeats
    so you get first maxima at t=1/4800 and second at t=1/4800 +1/400 (k=1) , and so on.....
  7. Apr 2, 2016 #6
    Thank you .
  8. Apr 2, 2016 #7
    PeroK
    That's the answer given on plate. However, you should note that:
    1) Sine oscillates between -1 and 1 (not 0 and 1).
    2) Sine has maxima for negative integer ##k## in addition to posiive integers.
Have something to add?
Draft saved Draft deleted
