Wave speed in water.
  • Thread starter asz304
asz304
108
When you slosh the water back and forth in a tub at just the right frequency, the water alternately rises and falls at each end, remaining relatively calm at the center. Suppose the frequency to produce such a standing wave in a 64.6 cm wide tub is 0.835 Hz. What is the speed of the water wave?
2. The attempt at a solution
v= lambda*f
L = 1/2 lambda
v = 2L*f
v= 1.07 m/s
My Question:
Why is the width of the bathtub 1/2 the wavelength?
I'm confused.
Thanks
Answers and Replies
tiny-tim
25,836
255
hi asz304! :smile:
(have a lambda: λ :wink:)
there's gotta be two nodes in each wavelength! :smile:
(alternatively: one side is a peak when the other side is a trough, but a wavelength is peak to peak)
asz304
108
It's getting a bit clearer.
So a node is like a point in the maximum?
Silly question: Where does it say in the question that the wave has only 1 wavelength?
Thanks
tiny-tim
25,836
255
no, a node is stationary …
sloshing to the right, sloshing to the left, but no sloshing at the node :smile:
Where does it say in the question that the wave has only 1wavelength?
it doesn't
the definition of a wavelength is the length from peak to peak …
if you can only see one peak and one trough, you have to double that to get peak to peak :wink:
asz304
108
Thanks :D.
Suggested for: Wave speed in water.
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
50K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
