Wave superposition.
  • Thread starter Lavabug
37
Determine the amplitude and phase of the luminous disturbance produced by the superposition of N waves of the same amplitude and phases which increase in an arithmetic progression ([itex]\delta[/itex],[itex]2\delta[/itex], ...[itex]n\delta[/itex])
Using the trig identity cos(u+[itex]\delta[/itex]), where [itex] u=(kr-\omega t) [/itex] I rewrite the resulting wave(with asterisks), which is a linear combination of n waves with different phases. Associating the coefficients I get the following 2 equalities:
[itex]A^*cos\delta^* = A \sum cos\delta_n[/itex]
[itex]A^*sin\delta^* = A \sum sin\delta_n[/itex]
Beyond that it gets ugly if I try to solve for A* or δ*, for example squaring both and adding gives me:
[itex]A^* = \sqrt(A^2 ( \sum cos\delta_n)^2 + ( \sum sin\delta_n)^2)) [/itex]
is there another way to do this?
Answers and Replies
ehild
15,543
1,914
Use the Euler form of the waves: B*e= A*∑einδ.
ehild
37
I also tried that but it leads me to the same set of equations, is my solution for A* correct? Cause I can't think of anything else to do with it.
ehild
15,543
1,914
Aeiδn is element of a geometric sequence with quotient e and Ae as first element. The sum of N element is the resultant wave.
[tex]B e^{i \theta}=A e^{i\delta} \frac{e^{i \delta N}-1}{e^{i\delta}-1}[/tex]
Factor out eiδ N/2 from the numerator and eiδ/2 from the denominator:
[tex]B e^{i \theta}=A e^{i\delta (N+1)/2} \frac{e^{i \delta N/2}-e^{-i \delta N/2}}{e^{i\delta/2}-e^{-i\delta/2}}=A e^{i\delta (N+1)/2}\frac{\sin(N\delta/2)}{\sin(\delta/2)}[/tex]
ehild
Related Threads on Wave superposition.
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
