Finding Average Values in a Waveform: Understanding the Concept and Calculation
In summary: Below the average consider the squares to have a negative sign, above the average line call them positive. So when you have it correct, the differences cancel.
Marcin H
306
Circle all that are correct
V(t)=Vocos(wt)
I don't really understand what the question wants when they ask for an average value. Average value of what? And how do you find it. There are a lot of questions with graphs like this that ask to find the average value, but I'm not sure how to get that exactly. How do I find the average value of this problem?
On a graph, the average value is drawn as a horizontal straight line at a level such that there is as much enclosed area above that line and the waveform as there is below that line and the waveform, for one cycle.
Oh. So do you get the average by just looking at it or is there a formula to get it. Looking at this one it looks like the average would be 0 right? How can I get the average for something like this:
The easy ones you can do by inspection or by counting squares, but for the harder ones you need to use integral calculus.
Did you plot a horizontal line at y=0 on that graph, to check that it looks about right?
This is a non-calc based course, so is there an easier way. I've taken up to calc 3 and some diff eq, but I don't think we can use calc for this. (This is EGR 110 - Intro to comp E and EE) Also, the way my teacher does it doesn't make sense... :/
I looked at one cycle and saw that the triangles would cancel each other out, so it's average would be 0. I think.
For the triangular waveform, yes, its average is zero.
How about for the other one? Is there a simple way of doing it?
Counting squares. Half will be above the average mark, half below it.
Where would the average mark go? Horizontal line at 1Amp?
How many "squares" do you count between that line and the waveform?
Which line? The horizontal line at 1Amp? 7.5 boxes
Why the 1A line?
What is a waveform?
A waveform is a graphical representation of a signal over time. It is a visual way to represent the changes in amplitude or strength of a signal over time.
What is the average value of a waveform?
The average value of a waveform is the sum of all the values in the waveform divided by the total number of values. It is also known as the mean or the arithmetic average.
Why is the average value important in analyzing waveforms?
The average value is important because it gives a measure of the central tendency of the waveform. It can help in identifying any trends or patterns in the signal and can be used for comparison between different waveforms.
How is the average value calculated for a periodic waveform?
The average value for a periodic waveform is calculated by taking the average of one complete cycle of the waveform. This is also known as the average over one period.
Can the average value be negative?
Yes, the average value can be negative. This can occur if the waveform has both positive and negative values, and the sum of these values is negative. It is important to consider the sign of the average value when analyzing waveforms.
